Emergency brake light stays on 1981 SC
Just yesterday when I released the E- brake the light stays on. What are the reasons for this?
Thank you Barclay _______ 1981 SC |
Check your brake fluid level as well. Low fluid level can also trigger the light.
Cheers,
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
As can a failing alternator; brake warning light is used as a type of "master alarm". Jim
Brake fluid is full. So are you saying the brakes are going when the light comes on or the master cylinder? I did adjust the e-brake cable about two weeks ago would that do it?
Check the micro switch under the E-Brake handle. Make sure it's hitting that switch to turn off the light.
The Fox Carrera |
I'm with Bill
I just went through this about 2 months ago with my 82.
Unhook the battery for about 30 seconds. Hook it back up and start the car if the light stays out you need to replace the 2 switches on the master cylinder. They operate indipendatly but are tied togeather as a way of checking each other. Check to see if you have brake lights. I might add it happeed while my wife was driving the car she got scared " I broke Ricks Porsche!" It was a good laugh.
Electrical problems on a pick-up will do that to a guy- 1990C4S |
I'm with Bill
If it is not the parking brake switch the light will dim slightly when you release the brake lever.
Are we talking the E-Brake or the Brake Pad wear light?
The Fox Carrera |
I'm with Bill
I don't believe an 81 has a pad sensor on it. I could be wrong though, wouldn't be the first time
There is no wear sensor on the brakes. There is one on the master cylinder if your fluid is low. So I check it and put a very small amount in. Then I pulled the clock out unplugged the brake light switch and plugged it back in....it seemed to work.
Thanks to everyone for there help Barclay ________ 1981 SC |
