-   -   CHT testing question (http://forums.pelicanparts.com/porsche-911-technical-forum/243613-cht-testing-question.html)
NY65912 09-29-2005 04:30 PM
I just tried to test my CHT on the '85 TL. I've had problems with a rich mixture.
The CHT only has 1 wire hence 1 pin. The connector from the DME has 2 pins.
I tried testing the resistance, ohm meter touching the 1 pin on the CHT and ground, I got a reading of 2.54 ohms, within spec I believe.
I thought I might test for continuity, same placement and there is no continuity. Should there be continuity?
Is the CHT good, bad or ugly?
Any help welcomed.
greglepore 09-29-2005 04:32 PM
Not to be a wiseguy, but how can there be no continuity if there is resistance? If there is resistance anything other than infinity, there is by definition continuity.
NY65912 09-29-2005 04:34 PM
My point exactly Greg.
john walker's workshop 09-29-2005 04:55 PM
it's the old style anyway, so yank it and install the newer two wire sensor. the one wire sensors cause various running and dying problems when they get old, which they all are now.
NY65912 09-29-2005 05:16 PM
Thanks John, I'll order one up now. What is with the 2 pin connector and single pin sensor though?
PatrickB 09-29-2005 05:49 PM
So even if you happened to replace with a new OEM single wire CHT, it will suddenly not work either?
PatrickB 09-29-2005 05:52 PM
let me be more specific!
a new OEM "style" single wire CHT....
john walker's workshop 09-29-2005 07:11 PM
there are none. all two wire now.
