-   -   DME relay Installation (http://forums.pelicanparts.com/porsche-911-technical-forum/243619-dme-relay-installation.html)
frenchy 911 09-29-2005 05:14 PM
I am planning to change my DME relay and was wondering if someone had a step by step for this. I know the relay is located under the driver seat but did not seem very accessible even with seat move all the way back. @ cylinder under the seat seems to be blocking the access.
Do I need to remove the seat???:confused:
kqw 09-29-2005 05:55 PM
NO, you don't have to remove the seat.
Look at the DME relay. There is 1 nut holding the Relay. You should be able to see it if you slightly push the cable plugged into the DME computer.
frenchy 911 09-30-2005 04:38 AM
thanks will take a look today
