73 sunroof wind deflector hinges
The left-most hinge on my sunroof wind deflector has snapped. This is a very small piece. Where can I source a new one?
Its all one assembly (left wind deflector) PN 90156407305; Pelican shows it is still available from Porsche for a cool $333.75 each. The part number for the B3.9 x 9.5 lense head sheet metal screws used to secure the deflector is 90014500902; also available special order through Pelican for $1.78 each. You might check with Parts Heaven and other slavage yards for a used deflector. Jim
wowsers! thanks for the part numbers. so $335 gets me just the left side? is anybody doing a sunroof delete this week?
![]() it looks like the hinges swivel on a rod, do these dis-assemble at all? I know sometimes parts can only be ordered as a complete assembly, even though they can be dis-assembled into component parts. Last edited by billwagnon; 10-02-2005 at 07:16 PM.. |
If just the hinge pin broke, given the expense of a new deflector I would attempt to fabricate a new pin. If one of the hinge leaves fractured then that would be a lot more work but almost anything can be fixed give enough time and treasure. Jim
You might also put an add in the classified here. It seems like I have seen those parts a few months ago. Maybe do a search
Dean
Dean 911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno, |
What are all the racers doing with these items when they remove the sunroofs from their cars?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
1.367m later
non velox ad propitiare, verisimile non oblivisci If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR. |
thanks Kevin that would be awesome.
Montana 911
I have had mine in the same condition for the past few years...what a pain in the arss.
H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R |
disband
mine is missing from the left side too. i suspect the hinges are the same all the way accross, 4 of them i think. i need one too if there is any left after billy and handler get theirs.
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
my deflector has a broken hinge, it seems like a common problem, let us know how you make out!
Good luck, it seems you may have found a source! Terb 74 Carrera (sunroof) 58 Cabriolet
air-cooled |
