Pic of Cylinder Head Temp Sensor location?
Hi,
Can someone please post a pic of exactly where the Cylinder Head Temp sensor is situated on the '84-'89 Carrera? I've read it's near Cyl # 3, but can someone please post a pic for me plz? Is it (i.e: the wire going into the engine) visible when you raise the car and remove the left tyre? Thanks in advance SmileWavy |
Yep, that's it. There's a rubber seal in the engine tin the white wire goes through. Peel it back and the sensor is hiding there. If you need to remove/replace it, you'll need to purchase or fab up a special tool. I made one out of a deep socket welded to a box end wrench with a slot cut in the side to clear the wire. It's a pain in the a** to reach, but it can be done.
Mike |
Cyl. head temp. sensor location
Merv,
Two pics that show sensor location in my 85 3.2.Wire runs up thru grommet above @ tin work. Hope these are what you needed!:) http://forums.pelicanparts.com/uploa...1128080784.jpg http://forums.pelicanparts.com/uploa...1128080830.jpg Let me know if these help! Chris |
Another shot w/tin
Here's one with tin & rubber seal in place.
http://forums.pelicanparts.com/uploa...1128081246.jpg Chris |
Great! Thanks for the pics Chris ;)
At least I now know where to look :D What's the BOSCH part # for this component? |
Another approach is to cut the wire and take the old CHT sensor out with a standard deep socket. Tape the new plug end to the clipped wire to help fish it back into the engine compartment. Use a pair of needle nose pliers to tighten the new CHT. Fairly strat forward once you are in there. The hardest part is getting the gromet seated.
| All times are GMT -8. The time now is 07:34 PM. |
