-   -   Front Clunk after Bilsteins install (http://forums.pelicanparts.com/porsche-911-technical-forum/243707-front-clunk-after-bilsteins-install.html)
cicsprog 09-30-2005 07:21 AM
1988 911 Cab. On driver-side front when hitting a bump I hear a clunk. Boge struts. I adjusted the front wheel bearing play thinking this was the problem. I jack up the front and grasp tire and shake. I can see some slight play with the shock. Anything to worry about? Maybe with in tolerence? Shut up and drive?
Jason
88 Cab
Wavey 09-30-2005 07:27 AM
How did you torque down the cap on the insert? You almost have to use the proper wrench to get it to the correct spec of 95 +/- 7 ft-lb. I wouldn't ignore it.
}{arlequin 09-30-2005 07:35 AM
wavey,
are you referring to the metal dust cap torque?
cicsprog 09-30-2005 07:43 AM
Would I tighten to that torque with the front driver-side jacked up? Or sitting on the ground?
Jason
cicsprog 09-30-2005 07:45 AM
opps...Wavey...reread your post....forget my previous question. Shock needs to come out is what you are saying to tighten down (i.e. cap on the insert).
Jason
Wavey 09-30-2005 07:54 AM
Right - the cap that secures the insert into the strut. I've seen those loose on other cars and it causes a clunk as the insert moves up and down inside the strut. I don't think you can get a wrench on it with the strut installed because of the dust cover.
cicsprog 09-30-2005 11:21 AM
yep...they were loose. I thought we had those things tight. No more CLUNK now. Drives better too! As usual this board is ACES! THANKS!
Jason
