-   -   Question onn 993 caliper rebuild... (http://forums.pelicanparts.com/porsche-911-technical-forum/243886-question-onn-993-caliper-rebuild.html)
efhughes3 10-01-2005 12:41 PM
I'm rebuilding a set of calipers and the first piston's seal & dust boot aren't cooperating. The Brembo instructions say to install the seal, put the boot on the piston, and then insert in so the boot seats. I can't get the boot to seat this way.
I did find a website where the guy says to install the seals, then install the boots in the caliper bore/groove. THEN, you pull the boot over the piston (the hard part) and then insert the piston into the bore.
Based on my first result, the second method may make sense. Any input?
