hillelson1's Avatar
Send a message via AIM to hillelson1
930 sway bar/ engine removal
do i need to remove the swaybar in order to remove the engine/tranny assembly. on my car the sway bar is right under the mounts for the transmission. also if can i remove the sway bar with weight on the wheels or does the car have to be jacked up so the wheels are off the ground because right now i have the tires on blocks to drop the motor out. this is my first engine removal and any advise would be helpful.
thanks
-larry
Old 10-09-2005, 05:32 PM
Scott R's Avatar
Yes it has to come out, and with a pry bar you should be able to remove it even under load.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-09-2005, 05:56 PM
hillelson1's Avatar
now where do i detach it? from the body or from the each end ends?
Love cars lucky i got an early start
1989 911turbo project
1928 rolls royce
Old 10-09-2005, 05:59 PM
Scott R's Avatar
I do the ends first, but you could do it either way.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 10-09-2005, 06:06 PM
I'd remove the bolts (M10 with a 17mm head?) through the drop link first then the 2 small bolts (M8 with a 13mm head?) that hold the bar to the mount.
And yes, the bar has to go before you can drop the engine/tranny assembly as others said.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 10-10-2005, 04:57 AM
