-   -   HELP, Cylinder Head Temp Sensor Install (http://forums.pelicanparts.com/porsche-911-technical-forum/244024-help-cylinder-head-temp-sensor-install.html)
ncseahawk 10-02-2005 02:59 PM
Gentlemen,
Any help at all on specifics to the sensor install would be of assistance.
Bentley manual is woefully inadequate for me. I'm sure some of the more experienced guys have done it.
thanks in advance
rcaradimos 10-02-2005 03:10 PM
http://www.pelicanparts.com/techarticles/911_cyl_head_temp_sensor/911_cyl_head_temp_sensor.htm
rcaradimos 10-02-2005 03:21 PM
http://forums.pelicanparts.com/showthread.php?s=&threadid=6578&highlight=head+sen sor+replacement
CharlesJones 10-02-2005 03:23 PM
I don't know if this is any help to you or not, but I just used a 14mm ring spanner with a gap hack-sawed out of it to accommodate the wire to install mine. This saved me having to buy the special porsche tool for the job.
WydRyd 10-02-2005 03:57 PM
I've read you don't even need a special tool. Just use long needle nose pliers?
