-   -   Self install Cat Bypass (http://forums.pelicanparts.com/porsche-911-technical-forum/244160-self-install-cat-bypass.html)
MPegler 10-03-2005 10:52 AM
Is this a fairly simple job? I'm keeping the stock muffler. I'm pretty experienced with DOY car repairs, but this would be my first Porsche project.
I don't have a torch etc., so I'm hoping that things come apart as expected. What should I watch out for?
Thanks,
Eugene at Pelican Parts 10-03-2005 10:55 AM
Rusty bolts. If doing it with the engine out, have an angle grinder ready. If it's still in, then a good dremel with lots of cutting disks. The nuts are usually 12mm, so be careful not to round them off with a 13mm wrench.
jason2guy 10-03-2005 10:58 AM
watch out for goblins. they live in there.
its easy. if you need help im in north hollywood
ChrisM911SC 10-03-2005 11:07 AM
Not bad at all. Make sure you have replacement nuts bolts and gaskets. The gaskets shouldn't be reused.
ausgezeichnet 10-03-2005 11:18 AM
I hit all my bolts with PB balster several days before the removal. All came off with normal wrenching.
fuelie600 10-03-2005 04:51 PM
It all depends on how rusty the nuts and bolts are. I had to cut (grind) all of the heat shield bolts off, then I had to cut the three bolts between the cat and the muffler. I was able to remove 3 of the 6 bolts between the cat and the header pipes. I had to cut the other 3! This was after soaking all of them in PB blaster for two days in a row prior.
It's not a hard job, but it requires lots of patience.
Good luck!
TerryH 10-03-2005 05:47 PM
Heat shield was missing on mine already, but I did take the left rear tire off so I could have a straight shot at a couple bolts. You want to make sure you give it your best shot the first time because if the bolts/nuts round off, then you're grinding. Mine were rusted, but came off pretty easy.
It was only after I removed the cat to install the bypass pipe, did I see the cat was empty. I bought new hardware/gaskets and reinstalled the gutted cat instead of the bypass pipe. Stock looking at least means I can pass visual emissions without having to R&R that bypass pipe.
