cycling has-been
bkreigsr's Avatar
brake fluid absorbent?
my catch can for the fluid over-flow became dislodged during an autocross & spilled about 4 oz of fluid into the pan of my 73.
it sat there for a month, until last nite when I went in to replace a fuse & saw the mess. it has eaten thru several layers of paint and undercoating , and to bare metal in a quarter-sized spot.
I cleaned up with wire brush and vacuum but the undercoating still feels damp to the touch.
Is there a product to counter-act the corrosive effects, like baking soda to electric crud?
thanks
Bill K
Old 10-05-2005, 05:23 AM
Friend of Warren
Not that I know of. Just flush the area out with water.
Kurt V
Old 10-05-2005, 06:32 AM
Crusty Conservative
silverc4s's Avatar
I would try simple green, or some such industrial cleaner. If you think that the brake fluid is still in the metal and will inhibit proper paint adhesion, you might try a trick I learned from a body/paint guy working on my car years ago. He used a Muriatic Acid solution to clean the metal prior to painting. That's like pool cleaning solution, be careful with the stuff, it is very caustic to your skin, eyes, etc...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 10-05-2005, 07:15 AM
