-   -   I need a little front suspension help please. (http://forums.pelicanparts.com/porsche-911-technical-forum/244475-i-need-little-front-suspension-help-please.html)
Jeff 10-05-2005 09:37 AM
I am trying to lower the front of the 76 and the adjustment bolt is all the way out. I was wondering, to get more travel out of the front adjuster do I need to remove the bolt completely and pull the torsion bar end cap/ adjuster off, jack up the hub a bit and put the end cap back on a different set of splines (reindexing if you will)?
Does the end cap/ adjuster just pry/ pull off?
Thanks.
Rot 911 10-05-2005 09:48 AM
Sounds like you have it figured out. Not hard to do. Maybe 5 minutes.
Jeff 10-05-2005 09:49 AM
Cool, Thanks Kurt.
