headlight wiring problem
Does any one has a picture of the back of the headlight with the wires connected?/
I disassembled both my headlights to paint the car and now I don't know how to assemble them back. I am not so worry about the 3 wires going to the head lamp, since I have already found info here in BBS on how to connect them, but what about all the other wires??
Where do i connect those?
Mario
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 10-05-2005, 08:05 AM
RallyJon's Avatar
What kind do you have? On H1s, the left (as you look at the back) is high, center is low and right is ground.
993 · 911 · STI · S4 · rally car
Old 10-05-2005, 08:42 AM
I haven't replaced/upgraded my sealed beams yet..but from the info that I have gathered here...in addition to the headlight wires [high ,low and ground]the harness also has 2 additional conductors for the parking lights and the direction lights. From the pelican wiring drawings they are: the left parking light wire is black/grey and the left turn signal is black/white. The right parking light wire is black/red and the right turn signal is black/green. Those two wires come up into the headlight bucket and plug into a connector. They are then routed out of the bucket and down to the directional lamp assembly. The directional lamp assembly has a cable hanging off the back of it [and two blade connectors inside of it] that routes power from it to the additional sidemarker lamp.
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 10-05-2005, 01:21 PM
Thanks for the info. this will make the job easier, so far I was only able to decifer the 3 headlamp wires.
Mario
'15 GT3
Old 10-06-2005, 01:13 PM
http://www.pelicanparts.com/911/911_Parts/Electrical/911_electrical_82SC_Part2-1.jpg
Peace, Ron
www.ronorlando.net
Old 10-06-2005, 02:59 PM
