jbscheff's Avatar
Red face Corroded hubs
I took my front wheels off recently and discovered some very disturbing corrosion where the brake discs attach to the hub. It doesn't appear that the corrosion extends into the heart of the hub, but I'm not sure I want to risk it. Has anyone seen this kind of problem before? Should I really be worried?
Jason
'73 911 Carrera RS clone w/3.0
Old 10-07-2005, 04:26 PM
Ayo Irpin, Ukraine!
70SATMan's Avatar
If it were me I would not drive that car until that hub is replaced. I've seen that type of corrosion totally eat aluminum away.
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 10-07-2005, 04:42 PM
syncroid's Avatar
Those are the worst looking hubs I have ever seen. I would replace them if it were me. If you don't you will most likely be plagued with brake rotor runout. (at the least)
Dan
2002 996 C4 Cab w/ Jake Raby 4.0
2024 Tacoma TRD Offroad 4x4
2003 Range Rover HSE
Old 10-07-2005, 04:57 PM
randywebb's Avatar
How did that happen in Calif.?
Did you buy the car recently? Was it registered back East maybe? Did a PO park it in the Pacific for a while?
Clean the white crud off and start probing into the bosses on the hub - post what you find....
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-07-2005, 06:07 PM
Bird. It's the word...
Fishcop's Avatar
You risk shearing a wheel off... change them.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 10-07-2005, 07:08 PM
san diego exhaust fasteners are among the worst i've seen. must be the salt air. new hub time for sure.
206 637 4071
Old 10-07-2005, 07:10 PM
don911's Avatar
Those hubs do look bad. I've been looking for a source for new hubs. Anyone know if new hubs are still available?
Don
24 Cayman GTS - GT Silver
23 Cayman GTS - Arctic Grey - Sold
97 993 Coupe - Arctic/Black - Sold
13 991 Coupe - Platinum/Black - Sold, 87 911 Coupe - Venetian Blue
syncroid's Avatar
Part # 901 341 065 04 $203.07 U.S. dollars. Price current as of July 2005 That is the part # for a 1973 car BTW.
Dan
Old 10-07-2005, 07:50 PM
Fishcop's Avatar
The new price won't kill you, but I'm sure you can find some S/H jobbies off the board for much better than that.
John Forcier
Old 10-07-2005, 08:12 PM
jbscheff's Avatar
They do look pretty bad. This car belonged to my father-in-law almost since new. He stopped driving it sometime in the 90's when the windshield seals gave way and started leaking water. He gave it to me after it sat outside for many, many years. This is one of countless items that needed replacing. The car now wears a refurbished, bare-metal resprayed body, fresh interior and is motivated by a strong 3.0 from an SC. I'm hoping that I can find a good set of hubs at parts heaven or someplace. I've just got to resist the "while I'm in there" bug. Could be time for a brake upgrade if I can manage the cost.
Jason
Old 10-07-2005, 08:37 PM
SC Schrauber's Avatar
"While I'm in there" does not really count when it comes to brakes and -in your case- hubs. I did it all - lines, hoses, calipers, rotors, pads, fluid, hubs and bearings were good= total cost some $600,-
At least I know I can rely on my brakes. I never save a penny on brakes or tires.
Frank
Old 10-07-2005, 09:03 PM
