-   -   1983 911 Sc Wont Idle (http://forums.pelicanparts.com/porsche-911-technical-forum/244823-1983-911-sc-wont-idle.html)
Kevin Taylor 10-07-2005 06:00 AM
Strange thing happened on the way to work yesterday.
Engine started normal and had idle normal but after I
let it warm up I and left the house and got to the first stop
light it died.
Started back up ok but now it wont idle at all. Had to drive to work and back using the emergency brake and revving it at stops.
The only thing that's different from the day before is the temperature. It's about ten fifteen degrees colder now.
Any Ideas?
Thanks K.T.
1983 911 SC
1973 911 E 2.4 MFI
1965 Devin "D" - 1967 912 Power Plant
Rick Lee 10-07-2005 07:41 AM
Ah, the joys of CIS troubleshooting. How's your WUR? And loose hoses? How old's your fuel filter?
tony77targa 10-07-2005 12:11 PM
Hey Kevin
Im still learnin my CIS sys and have a couple cars arpound to xchange known good parts for suspect bad parts.... also you will probably get alot more help if you ask questions like thios in the bbs tech section...
Good luck !
Tony
ianc 10-07-2005 01:43 PM
Sounds like a vacuum leak right off the top of my head. Any flapping hoses? Clamps on the air intake boot tight? Any cracks? Do you have a popoff valve installed and is it seated properly? Will it eventually idle when it gets warm enough?
ianc
Porsche Head 10-07-2005 01:51 PM
Have a spare WUR if you want, it's a rebuilt with ~3k on it.
Kevin Taylor 10-07-2005 02:29 PM
Thanks for your responses. I'm at work right now
so I'll fool around with it over the weekend. It has pop
off and it's seated. not sure about how old the fuel filter
is. Had to drive the truck today. It wont idle when warm either.
It got to dark on me to play around much last night. I was able
to check for vacume leaks but saw nothing. Will spend more
time with it in the day light with some help from my brother.
As if I did'nt have enough on my plate as it is. Just gutted the
bathroom and need to get back going on that project.
Thanks Again. Have Good Weekend All
K.T.
1983 911 SC
1973 911 E 2.4 MFI
1997 GMC 4X4 Z-71 SIERRA
