-   -   What is this engine? (http://forums.pelicanparts.com/porsche-911-technical-forum/244864-what-engine.html)
ishmeal 10-07-2005 10:11 AM
What can you tell me about this engine from this pic? Besides it's a bit dirty.
http://www.mtbdiaries.com/pics/engine.jpg
pierre p. 10-07-2005 10:16 AM
If the upper channel is the original, 2.7L
silverc4s 10-07-2005 10:17 AM
Hmmmm letsseeee...
Early MFI with magnesium stacks 1969-1971??
Crummy 5 blade fan from mid 70's era
No carrear tensioners
Green E type engine shroud
Air cleaner same as my 70 S MFI
Parts missing from front of MFI pump
Non standard fuel filter (not for MFI AFAIK)
Bosch Distruibutor - no vacuum
ishmeal 10-07-2005 10:24 AM
It's s'posedly from a 1970 911E. Does that mean, mfi? What else can you tell me is wrong with this engine?
silverc4s 10-07-2005 10:34 AM
I would have guessed 1970 E, based on the MFI stacks & air cleaner, but that's the wrong damme fan!!! POS that is not adequate to cool the engine, should have 11 blades.
Get the engine type number & serial number off the right rear of the case, down close to the engine tin and right of the fan housing. It should be a 911/01 or 911/04 engine type as a 70E.
Post those here and we can tell you what base engine is there..
