-   -   How do I attach a replica Paint Code Plate? (http://forums.pelicanparts.com/porsche-911-technical-forum/244879-how-do-i-attach-replica-paint-code-plate.html)
911T1969 10-07-2005 11:40 AM
Just wondering If anyone had some tips on installing a replica Paint Code Plate. Also can anyone post a picture of an original paint plate for a '69? Thanks!
kenikh 10-07-2005 11:52 AM
I am doing this soon as well; I believe that the correct method is to use expanding rivets, available from Stoddards. This topic has been covered at length here:
http://www.early911sregistry.org/forum/search.php?searchid=88380
911T1969 10-07-2005 01:08 PM
Also, in 1969 did Porsche us the xxx-x-x format for the paint codes?
kenikh 10-07-2005 01:13 PM
Dunno; I'd ask this question on the Early 911 BBS; you'll get more responses.
fryardds 10-08-2005 03:20 PM
I don't think this format was used in '69. My '70E coupe has the XXXX-H, where H stands for Herberts. There were several different paint manufactures used by Porsche and in the early years they were abbreviated with letters, H for Herberts, G for Glasurit, L for Lesonal. Also there was no number used for the coach builder on the early tags.
I am planning to attach my replica paint tag for the '71 Targa with adhesive. I will glue the rivets in the holes in the plate and then glue the tag on the door post. I am not even going to attempt to use the rivets to hold it on.
911T1969 10-14-2005 05:02 AM
Brian, I went to nuts and bolts specialty store in my town and asked it they had "drive screws". The man knew exactly what I was talking about. I showed him the paint code plate and told him I needed the smallest they had. He came back with 4 drive screws that will work perfectly. The drive screws just tap in and the heads look like the originals.
davidppp 10-14-2005 05:31 AM
Slightly off-topic..
Please can anyone tell me where to get thes plates , and also the replacements for the chassis plate?
Stamping them is an issue too..
911T1969 10-14-2005 05:33 AM
Anyone have a picture of an original pre 1972 911 paint code plate?
In '72 Porsche change the format of the code. I know the older code format is XXXX-X, but is this the only code on the older plates? Anyone have any luck matching the font of the code?
911T1969 10-14-2005 05:41 AM
I had done a search on Pelican and could not find the paint code plate, so I got mine a www.*************. I don't know about the VIN number plate.
