-   -   New LM1 Setup (http://forums.pelicanparts.com/porsche-911-technical-forum/244985-new-lm1-setup.html)
wilke3169 10-08-2005 06:19 AM
New LM1 Setup
OK I did search and I have read a good deal of the 103 page manual and I have stayed in a Holiday Inn Express but I need help. I ordered and received a LM1 with rpm kit. I used the quick start info and did a 10+/- minute run with my car. Attached to the port on my computer and I am having little to no luck. Every time i attempt to start logworks I get a "No HW detected" message. I did download the info which I now have on a chart showing two sets of voltage readings. I am a plug and play computer guy. I like printers that work when you plug them in. Is my ignorance getting the best of me or is this more simple than I am making it? How can one rebuild a Porsche engine using a book and have success but cant operate a tool that makes that engine better? I am going to breakfast to think about this. Any help would be appreciated and i also would appreciate any links to threads that will make this set up less complex than I am making it.
Thanks,
Kevin
jbrinkley 10-08-2005 06:26 AM
you tried over here? http://www.innovatemotorsports.com/forums/index.php
I've still not figured out all the ins and outs
beepbeep 10-08-2005 06:47 AM
Realtime logging with new software works only when 12V cable is connected, as far as I remember.
WBO2 sensors must be connected and heater-voltage engaged in order to connect trough RS232.
svandamme 10-08-2005 09:00 AM
yep...
9volts battery in the lm1 is for basic functionality only
you need 12 volts to power the WB sensor
9 volts should be enough for the laptop to connect to the lm1... it should connect, and tell you no power on the lm1 and on the laptop if 12 volts is not connected
beepbeep 10-08-2005 12:15 PM
Originally posted by svandamme
yep...
No. Not with LogWorks 2.0. You need 12V or you get "cannot find HW" popup upon start.
LW 1.4 could connect to LM1 powered by 9V.
svandamme 10-08-2005 12:35 PM
can't say i noticed a difference after updating, so with LW2 , you can't simply log data, then takeyour LM1 and download it to your laptop without the 12V?? strange, i'll check again tomorrow, i've been taking my laptop to my car, not the lm1 to my laptop...
klatinn 10-08-2005 01:08 PM
Hi,
Yes you can. Different to LW-1, LW-2 detects realtime packets when it starts up. If it does not find any, it will display "no hardware detected". This message will be changed to "no realtime packets detected" in an upcoming maintenance release.
But despite the message you can still download logs from the LM-1 in the usual manner.
Regards,
Klaus
wilke3169 10-08-2005 06:30 PM
OK I have it working somewhat. I did take the laptop down and it works much better that way. Still need to work on changing display values on downloaded files.
My RPM adapter quit working. Was working fine and died. No light or anything. I tried to reset and recalibrate. As if it isnt there. It appears my setting was pretty close to begin with. Went for a drive with the LM1 in place. Looking forward to mapping a few enthusiastic runs. Thanks for the info guys.
Kevin
