-   -   Quick WUR Question (w/ pic) (http://forums.pelicanparts.com/porsche-911-technical-forum/245059-quick-wur-question-w-pic.html)
TWork 10-08-2005 05:40 PM
I pulled out my WUR to open it up and clean out any gunk. Unfortunately, I had to pry a bit to get it to finally open up. When I did, I had parts everywhere. Well, I've found all my parts, but I wasn't able to see how everything was laid out beforehand. My I've figured out how the springs go (I think), but not clear on where the "hat" goes. Does it sit on top of the two springs with the point going up? I assume that's the way it goes, but thought I'd solicit input before putting it together and back into the car wrong.
http://forums.pelicanparts.com/uploa...1128818410.jpg
tsuter 10-08-2005 06:01 PM
The "hat" goes down towards the spring with a small metal rod that fits into the hole in the bimetallic spring.
john walker's workshop 10-08-2005 06:10 PM
use a dab of point grease to stick the pin in the hat. it keeps it pointing up so you can assemble the halves.
tsuter 10-08-2005 06:12 PM
Here is a photo to help. The hat goes down into the wire spring as a seat. It has a metal rod that then goes up to the bimetallic spring.
http://forums.pelicanparts.com/uploa...1128820314.jpg
Lot of these laying around the shop....
tsuter 10-08-2005 06:13 PM
Yup you can see the grease on mine..... keep it from falling out on reassembly
TWork 10-08-2005 06:43 PM
This forum never ceases to amaze me. Great members. Thanks for the info and pics. I didn't realize there was a pin. Sure enough, looking around when the WUR exploded, there was the pin laying on the ground.
Thanks again!
T.
