Certified Porsche Nut
Noisy Sunroof
My sunroof is very noisy when I open and close it. After driving the car for 18 months I decided at 11:45pm to have a look (?? Im sure Im not the only one guilty of such things).
Turns out that the noise is generated from a rubber hose like connection that is about 3 inches long and sits between the sunroof motor and the motor mechanism that actually drives the sunroof cables. When the motor is in operation this thing vibrates like crazy and generates the noise.
Now I know Porsche couldnt be that sloppy, and I cant find a part on pelican that fits the description, does anyone know the part number or what that part should actually look like?
Thanks in advance
(p.s. car is a 67, the sunroof is factory)
Old 11-21-2009, 06:00 AM
Ok, I found it
It is called a Pliable Shaft, part number 90156461506 and Pelican do sell it. I hope it isnt rubber...
Old 11-21-2009, 06:08 AM
Mine is really noisy as well and my motor will keep running until I remove my finger from the switch. What causes that?
Old 11-21-2009, 07:26 AM
Designer King
Paulporsche's Avatar
Its design. Mine has always operated that way. I think that's how it works. The connection described above works like a clutch to decouple the motor from the sunroof panel once the panel is in the desired position.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 11-21-2009, 07:31 AM
Well I got my pliable shaft. Sadly it looked like the one I already had, just the rubber was a different colour.
I installed it and to no surprise it made no difference.
When I first had the car inspected the mechanic told me that they are all like that (the noise). But I have been in a friend's SC that was whisper quiet.
Does anyone know why it rattles and how to fix it? Little help!
Old 11-26-2009, 04:04 AM
(the shotguns)
berettafan's Avatar
wish my car just had the vw style turn crank.
actually wish it didn't have a sunroof at all but i'm trying to wish in smaller increments these days.
Old 11-26-2009, 05:26 AM
Science is NOT optional
rbogh901's Avatar
Coming back to this...obviously I'm in good company.
The sunroof motor in my '72 does the same thing while the 964 sunroof operation is whisper quiet and butter smooth. Actually, when the motor in the '72 is disconnected from the drive cable and run it too is darn quiet, but bolt it in, hook it up and the whole thing makes quite a racket going either direction. OUCH. I tried to cushion the motor from it's connection with the drive but no improvement. Is there something missing that should be absorbing the vibration?
PCA member since 1993
Old 07-02-2010, 09:35 PM
Designer King
FWIW my original assembly made a lot of noise. When I replaced the motor, everything smoothed out.
Paul
Old 07-04-2010, 06:25 AM
I love the loud, robotic mechanical sound that it makes.
Old 07-04-2010, 09:00 AM
rs6er's Avatar
Send a message via AIM to rs6er Send a message via Skype™ to rs6er
^ +1 I have owned my car since new, and it has always made this sound.
John
Original owner '81 911SC blackmetallic coupe. Terbatrol, SSI, M+K Gen 4, SC+ cams, A/C delete, console delete, heater backdate, 7 & 8 x 16 Fuchs with polished rims, Turbo tie rods, tensioner update, Rennline engine mount bar, Mainely Custom sump plate, new top-end, corner balance.
Old 07-04-2010, 09:03 AM
