-   -   Where is fuse 22? (http://forums.pelicanparts.com/porsche-911-technical-forum/245099-where-fuse-22-a.html)
TWork 10-08-2005 09:01 PM
Where is fuse 22?
To make a long story short, I'm doing a MSD install. I'm not getting spark and I don't have battery voltage at terminal 15 of the six pin connector. According to the Bentley (page 280-9) 15 gets power from fuse 22 in main fuse box. I've looked at the fuse box table (971-2) and can't locate fuse 22. Anyone know where it is?
Thanks in advance,
T.
jorian 10-08-2005 10:57 PM
As there are only 21 fuses in the front (main) panel I would guess the fuse your looking for would be located in the engine compartment panel. Wheres' Warren when you need him?
TWork 10-08-2005 11:21 PM
Thanks Jorian. I thought that it might be in the rear, but according to the Bentley, none of those are ignition related. However, I had spare fuses, so I change all three in the engine bay, and it made no difference. :(
T.
jorian 10-08-2005 11:44 PM
See Bentley page 280-7.
If battery voltage is not present, there is either a fault in wire between terminal 15 and ignition switch, in ignition switch itself or in wiring from battery to ignition switch. Check ignition coil fuse. (#8 fuse in #1 [center] panel or # 11 fuse from right to left)
TWork 10-09-2005 07:20 PM
Jorian --
I wonder if there's variation in the Bentley manuals. My books doesn't say anything about "check ignition coil fuse." I did change fuse #11 with no change.
Anyone have suggestions on how to get power back to terminal 15 on the 6-pin connector that goes to the CDI box?
T.
patkeefe 10-09-2005 07:26 PM
Man, I hope you find 22. I was looking for 23 this afternoon (heater fan blower, 78 SC). I hope 23 is next to 22.
TWork 10-09-2005 07:39 PM
Pat --
I'm pretty sure the heater blower fan is the middle of the three fuses in the engine bay.
T.
Randy Blaylock 10-09-2005 07:43 PM
Strongly recommend you run a dedicated and fused power circuit to the MSD box, with good high strand count wire, minimum 12 ga, 10 ga possibly depending upon the run. They draw approximately 1 amp per 1000 revs. Doesn't sound like a lot, but most old 911s wiring is getting a little corroded and has extra resistance, you don't want to overload a circuit and cause other issues. Unless you're just looking for a switched 12V source to turn on the box, that's a different matter of course.
TWork 10-09-2005 07:48 PM
Randy, I'm looking for a switched 12v source to turn on the box. I already have the 12v dedicated source.
T.
patkeefe 10-09-2005 07:48 PM
Thanks, T:
Be nice to get the fan running. It's a bit damp and chilly here at Watkins Glen. I don't have any fuses in two of those three spots, and couldn't see the yellow/black wire coming from there (according to Bentley)
Pat
Also, I think the bottom fuse in that three fuse block powers the ignition system. I had a post a while back which Warren pretty much explained the power sources in. I'll post if I can find it.
patkeefe 10-09-2005 07:59 PM
http://forums.pelicanparts.com/showthread.php?s=&threadid=216716&highlight=plug+w ires
TWork 10-09-2005 08:55 PM
Thanks Pat, I'll take a look.
RickM 10-10-2005 07:02 AM
As mentioned, perhaps the rear fuse block: http://forums.pelicanparts.com/porsche-911-technical-forum/233095-1985-carrera-fuse-relay-layout-reference.html?highlight=fuse
Mysterytrain 10-10-2005 07:25 AM
22,23,24 are the fuses in the rear of the car
TWork 10-10-2005 09:03 AM
Okay, I'll take another look back there.
Thanks,
T.
randywebb 10-10-2005 11:58 AM
It's wierd they would say "main fuse box" if in the rear - see the intial post. A factory schematic will sort it all out.
TWork 10-10-2005 02:02 PM
That's the thing Randy, it definitely reads, "fuse 22 in the main fuse box...." And, not sure why ignition wouldn't be listed as one of the items that runs through the rear panel in the fuse listings in section 970 of the manual.
T.
patkeefe 10-10-2005 02:04 PM
Another reason to think that too much Porsche engineering was done at the brauhaus
randywebb 10-10-2005 06:18 PM
Yes - and I just realized... it has to do with the electrical system! So like everything else electrical on these cars... it is bound to be screwed up.
RickM 03-28-2006 07:15 PM
Here's the code:
5 Amp = Yellow
8 Amp = White
16 Amp = Red
25 Amp = Blue
Don't know if this will help but here's the fuse config for an '85 Carrera (Yellow, rear fuse appears to be for the Heater fan relay):
http://forums.pelicanparts.com/uploa...1122431230.jpghttp://forums.pelicanparts.com/uploa...1122431253.jpg
bsimonson 07-04-2010 01:33 AM
Since this confused me too at first I thought I'd just add that there is a note above "table a" on page 971-2 (in the Bentley manual):
"In the wiring diagrams fuse positions 1-3 in the engine compartment fuse/relay panel may also be referred to as fuses 22-24."
Note also that fuses 22-24 are quite the opposite between 78-80 and 81-83 models.
Cheers, Björn
moneymanager 07-04-2010 07:15 AM
For me this was simple. I checked the three fuses at the rear till I found one whose current was switched by the key. I wired the MSD there.
