plymouthcolt's Avatar
Replace these while engine is out or waste of money?
I will have to drop my engine soon to replace the clutch.
Waynes 101 book suggest some "while it's out" part replacement and I would like some opinions.
(My engine is dry and doesn't leak a drop.)
-Oil pressure switch
-Thermostat O-ring
-Oil breather hoses
-Oil cooler seals
-Pulley seal
-Breather cover gasket
Howard
2003 996tt
1997 911 Coupe Artic Silver (sold)
1988 Black 911 Coupe (gone but not forgetten)
Old 10-15-2005, 11:01 PM
VMAX1's Avatar
How many miles on her? Vacum hoses are very easy to get to and cheap. Dry rot from age?
Old 10-15-2005, 11:10 PM
Howard
2003 996tt
Old 10-15-2005, 11:17 PM
VMAX1's Avatar
I just put a clutch in my 87 carrera. I did put seals in front and rear tranny. Seals in the drive axles. Also, replaced the seals in the engine front and rear. You have to pull the metal shroud to get to the front seal, but you don't have to worry about engine leaks. 126k miles. There Is No Substitute!!!
Old 10-15-2005, 11:29 PM
Virginia Rocks!
VaSteve's Avatar
Re: Replace these while engine is out or waste of money?
-Thermostat O-ring
I would think that these three are on the "must do" list. IIRC the oil cooler seals can be done (but difficult) with the engine in. The hoses if they are worn (I reused mine). I didn't do the pulley seal.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 10-16-2005, 06:15 PM
I think the total parts cost for these are under $75 so I'd do it for peace of mind.
87 930 K27HFS/B&B/Twin-Plug... Megasquirted
Old 10-16-2005, 07:44 PM
I'd also change the cylinder head temperature sensor if it's the old type one pin connector type. It's easier with the engine out.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 10-16-2005, 08:04 PM
