How do you run the fuel pump?
How do you run the fuel pump in a DME car without the engine running so you can check for leaks?
Does just the key on do it?
Do I have to jumper at the DME relay connection or can I just put 12V on a fuse somewhere?
Old 10-09-2005, 09:54 AM
jump pin 87b and 30 with a fuse in line on the plug,there's a pic in bentley. if you need a pic let me know.
I'm futzing with mine right now.
Old 10-09-2005, 10:30 AM
