1982 SC won't start
Just came back from a DE @ Pocono-car ran flawless-shut car down to make room in garage and now the car won't start.
Charging system checked out as I had the battery replaced less than a month ago so that's good;fuel pump is running; no noise whatsoever from the starter. What's up here? Starter solenoid? What is really frustrating is that I just did a major service about 2 months and am starting to look at some later model c2 and 95 993 coupes and selling the SC. Suggestions please..... |
did you try to hit the starter with the hammer to see if it jammed?
http://www.mybuildgarage.com/author/carreraboy |
wait an hour or so and I bet it will start up like nothing happened.
Heat soaked starter.
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
No luck Paul. I think my starter is shot-shouldn't it be making a clicking noise at least???
Any relays or fuses I should be checking?? PS-I forget to mention my dashboard blower motor went bye-bye on saturday. |
Check to make sure the solenoid wire from the ignition switch is on nice and tight and that you're getting juice to it from the ignition switch when cranking,
ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
French member
I would unscrew the battery posts, clean them with a wire brush, ans rescrew. Sometimes, a ohmic drop there will prevent the starter from kicking in. Hapened to me...
Aurel
Aurelien '78 SC Targa, DC15 cams, backdated heat and exhaust, AC delete, Turbo tie rods New rings on Alusils...I did it! Hear my rebuilt motor! Dyno |
Happened to me when once in my 78, I pop started it and it has been fine since.. figured the starter was locked up somehow.
Gary R. |
If the starter were bad, wouldn't it be making a clicking noise?
There is no noise from the starter whatsoever. |
Check the 14-pin connector on the driver's side of the engine compartment. Perhaps it is loose.
Mine made NO noise at all, just heard the fuel pump going. All connections were good, assume it was a stuck solonoid or something. Can you roll the car and start it where it is?
Gary R. |
Senior Member
I would repeate Jim's advice. Check the 14-pin connector at the fuse panel in the engine compartment on the drivers' side. The fat yellow wire that goes through that connector is your starter circuit. I once had this same problem and it turned out to be a dirty pin. Clean the heck out of that pin.
Man of Carbon Fiber (stronger than steel) |
"Clean the heck out of that pin." Pins are silver plated so only use a no. 2 pencil eraser to clean. Pin fit can be tightened by spreading them at the crossed slits using a razor balde.
Gary-I rolled the car and it started-that is how I got it into the garage-and after I shut it off it wouldn't start again.
Jim and Superman-I will check that out after work; I did a DE and the car was out in the rain all weekend; however it ran flawlessly right til it died in the driveway. Thanks boys! |
Had a similar situation. It was after a long run in the dead of Summer. Waited a while and it started no problem! It did not make any noise - just nothing. Not that uncommon, from what I've gathered.
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
Should I replace the solenoid now or is it an isolated incident? Thank you all.... |
If it doesn't happen twice, it didn't ever really happen.
Thread Tools | |
Rate This Thread | |
