-   -   3.2 swap: tach (http://forums.pelicanparts.com/porsche-911-technical-forum/245228-3-2-swap-tach.html)
Shuie 10-09-2005 07:56 PM
3.2 swap: tach
Ive got the right tach on the way for my 3.2 swap into my '72. I know I have to run a wire somewhere to get the signal, but I have no idea where. Is it going to come off of the 14 pin connector? Whats the best way to do this?
TIA
Ben M 10-10-2005 04:42 AM
Attached is the charting or cross referance for the pins/wires from a early 70 to a 3.2, the tach wire is the black with a purple stripe. Hope it helps.
http://forums.pelicanparts.com/uploa...1128948025.jpg http://forums.pelicanparts.com/uploa...1128948042.jpg http://forums.pelicanparts.com/uploa...1128948055.jpg
randywebb 10-10-2005 11:15 AM
good time to clean all those little pins too
be ULTRA careful not to get them mixed up or broken, etc.
helps to have 2 people...
Sounds like your swap is going along so good luck.
deoxford 10-10-2005 11:25 AM
Sherman,
Keep us posted. Was it hard so far? What parts did you use from the 2.4 ...sheet metal? DId you put a hole in the rear seat area for the new wires? DId you take lots of pics.
What do you think your Hp will be?
Shuie 10-10-2005 06:06 PM
Thanks guys. Its not moving that fast right now. Im just trying to get everything lined out so that it goes smoothly. Ive got a bunch of work to do before I bolt the motor in. And still a lot more work to do before it ever gets fired up.
Derek, I dont know about the HP. Stock should be somewhere near 217. With all of the add on stuff I guess I might be near 230. It will be plenty for my skinny tires whatever it is. 217 is probably 100 more than I had before.
DonDavis 10-10-2005 07:35 PM
I'm also in the gathering stage for my 3.2 swap. I pressure washed the engine bay this weekend and will work on it more soon.
I'm stoked! The work has mostly been in a backwards direction (cleaning/prepping etc..) but its now starting to head forward.
Shuie 10-16-2005 04:24 AM
edit:
got it. Its the other black/purple wire off of the DME harness that goes to the front trunk :o. Thanks again!
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
