Licensed User
Shuie's Avatar
3.2 swap: tach
Ive got the right tach on the way for my 3.2 swap into my '72. I know I have to run a wire somewhere to get the signal, but I have no idea where. Is it going to come off of the 14 pin connector? Whats the best way to do this?
TIA
Old 10-09-2005, 08:56 PM
Ben M's Avatar
Attached is the charting or cross referance for the pins/wires from a early 70 to a 3.2, the tach wire is the black with a purple stripe. Hope it helps.
Old 10-10-2005, 05:42 AM
randywebb's Avatar
good time to clean all those little pins too
be ULTRA careful not to get them mixed up or broken, etc.
helps to have 2 people...
Sounds like your swap is going along so good luck.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-10-2005, 12:15 PM
Sherman,
Keep us posted. Was it hard so far? What parts did you use from the 2.4 ...sheet metal? DId you put a hole in the rear seat area for the new wires? DId you take lots of pics.
What do you think your Hp will be?
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 10-10-2005, 12:25 PM
Licensed User
Shuie's Avatar
Thanks guys. Its not moving that fast right now. Im just trying to get everything lined out so that it goes smoothly. Ive got a bunch of work to do before I bolt the motor in. And still a lot more work to do before it ever gets fired up.
Derek, I dont know about the HP. Stock should be somewhere near 217. With all of the add on stuff I guess I might be near 230. It will be plenty for my skinny tires whatever it is. 217 is probably 100 more than I had before.
Old 10-10-2005, 07:06 PM
What?!?!
DonDavis's Avatar
I'm also in the gathering stage for my 3.2 swap. I pressure washed the engine bay this weekend and will work on it more soon.
I'm stoked! The work has mostly been in a backwards direction (cleaning/prepping etc..) but its now starting to head forward.
running shoes, couple tools, fishing pole
1996 Subaru Legacy Outback AWD, 5speed
1964 Land Rover SII A 109
Old 10-10-2005, 08:35 PM
Licensed User
Shuie's Avatar
edit:
got it. Its the other black/purple wire off of the DME harness that goes to the front trunk . Thanks again!
Old 10-16-2005, 05:24 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
