Yes, I track my car quite a bit so checking them is not an issue. I have some very nice but very expensive PF-97s that I love on my SC Calipers right now and I am switching to the larger Carrera set up as part of a brake cooling upgrade and dont want to have to drop more money ontop of the Carrera setup unless I have to. Sorry to drag this off-topic for a momment, I just knew the knowledge was here.
Matthew “Sometimes the questions are complicated and the answers are simple.” |
Formerly bb80sc
![]() cheers -B
Cheers -Brad Porsche-less 2017 Mazda CX5 |
Brad,
It is generally accepted that the Boxster setup is more bling than function. As Bill V has stated many times, you really need larger rotors and cooling to deal with the heat. Using the same size rotor with a bigger caliper does nothing at the track. For the street it is fine though.
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
Thread Tools | |
Rate This Thread | |
