-   -   I need your help (http://forums.pelicanparts.com/porsche-911-technical-forum/245453-i-need-your-help.html)
Birmingham Bill 10-11-2005 06:11 AM
I need your help
My 1990 911 keeps going dead as I pull up to a stop sign, red light, etc. I have a guy that will work on it without losing a couple of rooms of my house and a small child. Although he is an excellent mechanic, he is not that familiar with Porsche engines. He needs to know what to change out. Here are the following guesses:
1. DME relay
2. Possible vacuum leak
3. Ignition coil and wires
4. Torque the manifold bolts down. Check the torque setting. I know on the carrera's it at 18 ft/Lbs
5. I was told there are 2-3 switches/relays that could be the problem, but I am not sure what they are called (any idea).
I know it is hard to diagnosis someone's problem without seeing the car, but I sure appreciate you trying. Thanks.
AFJuvat 10-11-2005 06:16 AM
Head temperature sensor. Located on cylinder 3 (left side of the motor, rear cylinder)
Bad DME relay: Car will not start
Vacuum leak: Car will run like garbage
Ignition: Same thing
Manifold bolts: Not likely
AFJ
Birmingham Bill 10-11-2005 07:39 AM
Thank you so much. So, forget the vac and ignition and concentrate on the head temperature sensor?
