oil drip trays
What do you folks use to catch oil drips under leaky vehicles in your garage? I notice in a lot of museums they have large, very shallow metal trays.... like huge cookie sheets. Does anyone sell these? Or do you just have them made at a fabricator? Any other ideas for catching drips? Thanks.
Longhoods Unite!
wife's or mom's (my case) cookie sheets!! just don't tell her!!!
1970 911T -- Neglected, oil burning problem, batman smoke 1974 914 2.0 Weber'd -- new project!! **My Wife and I bought our first house in August of 2009, the footprint of the house is just over 1100 sq. ft...my garage is just over 1000 sq. ft. We compromise well ![]() |
Friend of Warren
In my old Army Chinook Helicopter unit they used what looked like giant cookie sheets to catch all the hydraulic fluid those suckers leaked out. Whenever I had a car that leaked oil I flattened out old cardboard boxes and used them. Cardboard can suck up a huge amount of oil. Then just threw them away. At the present time none of my vehicles leak oil, even the British ones!
Kurt V No more Porsches, but a revolving number of motorcycles. |
Non Compos Mentis
Any auto parts store will have the big "cookie sheets"
old pizza boxes - their life cycle is:
- carry pizza - dawg chewie - oil drip catcher - refuse Or you can rebuild an Al engine and put an end to the whole problem.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I second the use of card board boxes. I also lay newer ones down when working under the car - to protect the floor and keep myself a little cleaner. Toss when yucky.
I used to work in a bakery when I was a kid. They had some giant cookie sheets there. Maybe
www.bakerycookiesheets.com or something. I found some drip pans from an outlet store but the bottoms had ribs and they are a ***** to clean. Find something smooth. On the other hand having oil drip on the garage floor is something cool and unique to 911 ownership.
Thanks, Mike When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE. 1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation) |
Cardboard boxes work great. Heavy enough to stay put when a gust of wind hits it and readily available.
88 Carrera Coupe Pelican Since 2002 All Zing, No Bling. ok, maybe a little bling. The Roach |
Some customers have discovered a secondary use of these. They act like a trough and allow oil to drip from one end or the other - no arbitrary dripping. This allows you to use a less expansive drip container ...... or smaller cardboard.
![]() ![]() Our host carries these, btw. Sherwood seinesystems.com |
I have duct taped square cardboard to my garage floor, after vacuuming, of course. the 911 sits in the same spot daily so it keeps the mess from tracking around the garage into the house. I keep a clean piece as well for laying on when working on it. Go to your local TV store and check with them. they should give you a couple of big hunks.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
for that you can buy a pizza and then use the box...
fill it w/kitty litter if you want.
I got mine from a resturaunt supply store. They are 2'x3' and they were around $15 each if I remember right. Get as big as you can to cover bigger areas.
1973 911 RS replica, Irish Green 1972 BMW 2002 1968 BMW 1600 1965 Triumph TR4A 1961 Land Rover Series 2 88 |
Most local auto parts stores around here sell a carpet like roll-up material. It works, just gets a little stiff from all the heat after the first year or two.
1977 911S Targa 2.7L (CIS) Silver/Black 1998 Chevy S-10 4x4 Pick-Up Truck, Razzle Dazzle Camo 1989 modified Scat II HP Hovercraft George, Architect |
Thread Tools | |
Rate This Thread | |
