PMO fuel pump advice
I appear to have a dead fuel pump on my 73 with PMO's(track car, RS spec 2.7 liter), I am going to check voltage to the pump and pull off a fitting to check if flowing but so far it appears to be the pump. The car has a old Bosch MFI fuel pump (580-980-009) to a 2 micron marine fuel filter to a PMO regulator etc. No return lines/dead headed. I searched the archives and found some great threads on systems but wonder what fuel pump the experts would put in this car if they were going to replace. I have a Holley Blue in my track spares
Richard Lane 1978 911SC 1973 "Clean" RS clone |
call Richard Parr...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
the holley blue pump will be more than enough for you car. if you can stand the noise, these are by far the cheapest and best fuel pump for carbed applications. this is what i am running on my current set up....
Hey Richard... PMO recommends the Mallory 4110 pump.. I've had good luck with Mallory products in the past... I'm planning to use PMO's on 3.2 short stroke engine ..with a mallory pump, with a return regulator.Dan
I have plenty of lead for my pencil... just not enough paper to write on.. 82SC with 95 993 engine 2004 Ford Powerstroke |
BTW, the Mallory pump can be purchased from Summit Racing for $159.95. Dan
So far, on my dead head system, I've had good luck with an Airtex pump. They make them in different pressure ranges. I use the 4 psi model; from tank to pressure gauge ends up at 3 psi. No FPR required. KISS.
This is my spare (existing Airtex in car since '98) ![]() Sherwood |
I am using a Holley Red mounted in the smuggler's box in my RSR Clone.
Noise..is this going to bother me? The car is 90% tracked, once it starts up it is barely muffled so I am thinking noise is relevant? Anybody have this issue in a track car?
What about running aeroquip fittings. I just redid all the fuel lines last year but I see more and more folks moving to aeroquip/Earls AN stuff.
The noise is a non-issue in a track car, or a loud street car. You can hear it when it switched on, actually kind of reassuring.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) |
I used this one you can get them at Summit racing. The regulator is 0-14 psi . This is the only way I have seen this regulator sold. As you are using the PMO regulator you could just get the pump. Mines a pure track car and its nice to Hear the pump running so that you know that the gas is going back to the carbs. Of course once the car is started I Never hear the pump.
http://store.summitracing.com/default.asp?Ntt=fuel+pumps&Ntk=KeywordSearch&DDS=1&searchinresults=false&N=0&target=egnsearch.asp Brand: Holley Product_Line: Holley Blue Electric Fuel Pumps Free_Flow_Rate: 110 gph Maximum_Pressure_(psi): 14 Inlet_Size: 3/8 in. NPT Inlet_Quantity: Single Inlet_Attachment: Female threads Outlet_Size: 3/8 in. NPT Outlet_Quantity: Single Outlet_Attachment: Female threads Quantity: Sold individually. Notes: Includes regulator. Fuel Pump, Electric, Rotor/Vane, Blue Logo, External, Universal, Aluminum/Polished, Regulator Included, Kit ![]() ![]() |
Richard -
I'm not clear from your post if you are using a deadhead or return style regulator. You say it runs "from the fuel filter to a PMO regulator etc. No return lines/dead headed" The only PMO regulators I've seen are return-style?? Anyway, I run a 3.0 with 46mm PMOs and FWIW have used both a Carter and now the "recommended" Mallory 4110 and had intermittent problems with both until I changed from a deadhead regulator to a return style. In fact, if you talk to Mallory tech support they will tell you not to run those pumps with a deadhead reg (ask me how I know). RE: fuel line, I tried the Aeroquip socketless lines and fittings (6AN) and have been happy with them. Easier and faster to work with than typical braided line fittings, the fittings are reusable and, the hose is lighter and not as abrasive as braided and, is less expensive. It's worth a look.
Gary Osborne Chardon, Ohio ___________ 74 911 IROC 98 Panoz GTWC |
I would rather be driving
Another option is the Bosch rotary pump. Similar style to the MFI but puts out about 4psi at the pump. Mine measures about 3.8 at the carbs when dead head terminated due to line loss. Runs great.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine classicautowerks.com - EFI conversion parts and suspension setups. |
Dave,
I'll try to get a few pictures of the Aeroquip lines tonight and post them here - Gary
I did check the fuel pump, it is a goner. I have another old Bosch, hooked it up and it runs but sounds ..unreliable. So I will go with the Holley. I notice the Holley says to mount vertically, I was hoping to modify the mount that exists in the 73 (back by the drivers side heater box). Anybody with pictures of one done that way.?
After reading all the threads and talking with Richard Parr at PMO I ordered his regulator and am going to replumb with a return line and -AN fittings
Here are some pictures of the Aeroquip socketless fittings and hoses. The fittings look similar to the typical braided line fittings but, to assemble, just cut your hoses to length, lube the barbed end of the fitting, gently clamp the fitting in a vice (or similar) and push the hose on until it bottoms out on the fitting. Quick and easy. The jacket of the hose is abrasion resistant and seems pretty tough and is avialbale in a couple of differnt colors.
thanks Gary, that's great to hear.
Thread Tools | |
Rate This Thread | |
