My 200.00 rat has RUSTTTTTTTTT
Hey for 200.00 what do you expect Well got the car home and started looking deep into the car 66 911] It has a new front suspension pan in the front and some patches in the floor then i looked closer and it looks like the pedal assembly area is bad but what really bothers me is where the suspension bolts into the rear section of the gas tank support [right side].. Im looking for this sheetmetal and its obsolete so what do i do?????? Does anyone know of a source for this area Thanks
Paul:
I met a guy at Hershey who may have this stuff. Ott's ********, I think it is. I have his number somewhere. If you can't find the sheet metal, we'll give you $250 for it.SmileWavy Pat |
Paul,
If you can’t find the parts it is best to carefully store the car in a controlled environment until they are available. In the interim, collect everything necessary to properly restore the 911. You are the current caretaker of a special Porsche vehicle. Don’t shirk your responsibility. If you are unwilling (I don’t think so) you should find someone restoring a similar 911 and sell/give it to a proper caretaker. Your find shouldn’t go unnoticed or unrewarded. It could have been crushed or let sit in a field. Best, Grady |
Thanks grady Im very excited about this one.although rough im looking forward to making a nice car of it
I need a pic of this $200 911
Paul, I know a thing or two about rust in 66 911's. Send me a PM and let's find a way to get together, I can take a look and tell you what you're up against.
My "driver" quality 66 will probably require $30K before it's all done to be reasonable for concours. The guys who WIN, well, their cars NEVER had rust, they were always perfect. Anyway, you might want to consider the entirety of the task before you start down the road. . . the most expensive Porsche is the one you get for free. . . NOT to discourage you in the slightest, but merely to give you the benefit of my experience in searching for, buying, and planning for the future of a SWB "NLA" car. Here she is. . . with her fat sister. . . http://forums.pelicanparts.com/uploa...1129085458.jpg |
John i sent you a PM with My #
The cars look great
hell, i'll give you $500 for it
Looks restorable to me. But, what I don't understand is this, "where the suspension bolts into the rear section of the gas tank support [right side]" The gas tank support is more commonly thought of as a component of the front suspension pan. Back under the cowel is another matter and is a part you would find at a salvage yard or a stripped toss-away shell. For instance, John Walker's Workshop has had some trouble in GIVING AWAY a 912. Wrong side of the country for you, but if you heed Grady's advice, you will come across what you need in time. Maybe a short time. Be patient. When I'm not patient and scramble for what I need and pay too much, the same item invariably shows up in the next month for peanuts.
Ask me about H1's and I can tell you this is so true. ;) |
For $200 I thought that I wouldnt be able to figure out that it was a 911. Now if that was the real price of ownership...:p
Paul, I proclaim your '66 911 "Barn find of the year: 2005"
Very nice, good luck! |
Basically, where the front beam goes through the hump, there's two front and two rear bolts, the bolt on the front side (gas tank side), drivers side for the beam. sjd |
Yes i believe thats it. Ive got a call into a shop that deals in these pieces as are host doesnt carry these That was the first place i looked. Im looking at a bit of welding,
Hell, the hood badge is worth twice what you paid for the car.
| All times are GMT -8. The time now is 11:55 PM. |
