Clutch conversion ?
930 4 speed; what do I need to change from the rubber disk to a spring type disk?
thanks |
clutch conversion
To clarify what I'm asking is; since the rubber center disk is much thicker than a spring center do I need some sort of a spacer/adapter or special throw-out bearing ...or?
thanks |
I'd call the company you're buying the clutch from. Are you getting something besides stock? Aluminum pressure plate perhaps?
2014 Cayman S 2011 Cayenne Turbo 1979 930 (475 rwhp at 0.95 bar) |
Thread Tools | |
Rate This Thread | |
