Monkey Wrench
Spede's Avatar
Oil warning light goes on when idling with a hot engine
When my engine is running a little hot, just a bit above normal operating temperature (usually in traffic), and I have my 911 in neutral the oil warning light goes on.
As soon as I put her in gear and give it some RPMs the light goes away. Actually, if I keep it in neutral and give it a little gas the light will go away but it will come right back when I let it idle again.
My oil level is dead in the middle of the normal marks on the dip stick. I have a 1984 euro 911.
Anybody have any ideas as to the problem?
Old 10-12-2005, 09:40 AM
slipping belt???
..oops thought you said alt light
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted.
Old 10-12-2005, 09:41 AM
Friend of Warren
What's your oil pressure gauge reading at idle? Should be around 1 bar.
Kurt V
DW SD's Avatar
Either you have low oil pressure or your oil pressure switch for the idiot light is broken. Hopefully, the latter.
Doug
1971 RSR - interpretation
Old 10-12-2005, 09:44 AM
I gets that tooo, but only when she is about die on me from not enough throttle (I sometimes start her up in 2nd as the tranny is tempermental)
1972 911T targa
Old 10-12-2005, 09:46 AM
pa911's Avatar
What wgt of oil are you using?someone suggested the other day to use 20-50 in warmer climates.
Old 10-12-2005, 09:47 AM
Monkey Wrench
Spede's Avatar
I'm using Mobil 1 15W-50.
I'll check the oil pressure light the next time it happens.
Old 10-12-2005, 09:56 AM
Thrasher's Avatar
In reading recently about my alternator issues, I saw one thread where the oil pressure light and alternator light had been reversed by a previous owner/mechanic.
It's worth checking, because a failing alternator would also begin to light up at idle and go away with RPM's.
Craig
'84 Carrera Coupe - B&B Headers and one-out muffler; K&N Cone intake; Steve Wong Chip; Euro height and corner balanced; 171K Miles (9/12)
Old 10-12-2005, 10:01 AM
Detached Member
Hugh R's Avatar
Pelican sells an oil fitting that goes between the block and the oil lines that feed the cams that is a little smaller internal diameter that is standard on newer cars than 84s that helps to boost oil pressure at idle. A number of people including me, have put them in.
Found it top of page this link http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_ENGcam_pg1.htm#item4
Hugh
Old 10-12-2005, 10:12 AM
My instruction book says it's normal behaviour with a hot engine.
carrera coupe 85
Old 10-12-2005, 10:21 AM
