Formerly bb80sc
Interchangable parts? PMO/Webber/TWM/Jenvey
Just wondering if some components, such as manifolds, linkages, and air filters are interchangable between these carbs and throttle bodies? Don't ask
Cheers -Brad Porsche-less 2017 Mazda CX5 |
Lots of parts are interchangeable (or so I hear). Most of the jets however are not.
jasper 2002 996 - arctic silver - PSS9, H&R sways,X51 oil pan, console delete, AASCO liteweight flywheel, gbox detent, RS motor mounts, 997 shifter. Great car. past: another 2002 996 and a 1978 SC with-webers-cams-etc. |
Weber/PMO manifolds and most of the linkage (drop links need to be shortened) will work with the TWM 3003 series bodies. The velocity stacks will have to be fabbed a bit to fit the 3003 series as the bolt holes don't line up. You will also have to do a bit of fabrication to get the watershields to work.
For the Jenvey's or the TWM 3006 series throttles there are no shared componants.
1971 Targa RS - Sold 1964 BMW 1800Ti 1969 BMW 2002 |
Thread Tools | |
Rate This Thread | |
