Limbo
Mounting seats to the floor?
Hi everyone,
I bought a nice set of after market seats and after installing them I realized I can't put my helmet on (seats set to high)!?!? ![]() How safe is it to mount the seats to the floor and what is a good method for doing so? Any suggestions and pics are welcome.... Thanks
Big ol built Duramax Durango R/T 19’ Current Custom project V8 M3 08’ Built and spoiled |
I'm also wondering how safe it would be to mount seats directly to the floor.
devalued member
i would think its ok if you were to put some sort of plate/cleat/anchor on the bottom side of the car. kinda sandwich the floor between the plate and your mounting hardware.
75S slick-lid webered, early n spicy 3.oL hotrod wanabe (sold 2/21} 78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ (build thread >) http://forums.pelicanparts.com/california-southwest-us-az-nv/443725-plunge.html |
yes, you could use backing plates.
I've also seen people cut the rails off and reweld them on the sides lower.
Andy |
Friends of Warren
I have my Recaro seats mounted directly to the floor.
I am confused by your set-up. How would you mount the seats to the sliders? Don't you need side mounts brackers like these ![]() ![]() What make seats did you get? These are mine bolted directly to the steel rails on the floor (I had to drill extra holes to get the right distance). PS This is an old picture and the side mounts were mounted back to front in this pic. ![]() |
Limbo
911teo,
I currently have the seats mounted to the factory rails, they set to tall in this fashion. My thinking was to mount the sliders directly to the floor. I even thought of using some 1 1/4" x 1/8" steel strap and mounting the seats to the strap and then mounting the strap to the floor with some large washers or plate on the bottom side of the floor to sandwich them together? The seats are an SRD clone... ![]()
Friends of Warren
Sorry... I automatically thought u had shells....
If I remember correclty the factory rails are bolted to the floor with 4 nuts and 4 gold plates. I don't see why there would be a safety issue by mounting the seat directly to the floor rails (by this I mean those 2 hollow rails that come up 1.5 inches off the floor. Inside these there should be the strap for the floormats plus possibly the wwires for the electric seats). You might have to cut some holes in the floor rails but apart from that it should be ok. You should be able to gain 1.5 inches of clearence. |
What's that on the left, Jeff?
Andy |
Limbo
Andy,
MUHAHAhahaha..... ![]() That is a little piece that I got from Alan Fritze, I also have 993 exchangers that have rotated flanges and a large port CIS airbox without a pop valve. I have a new design oil pump that bolts to the drivers side rear of the motor and runs off the cam (ala 930 oil pump) to scavenge the oil from the turbo...... This new pump is perfect for the newer bigger turbos that everyone is installing and can be adapted to none turbo (3, 3.2, 3.6) motors for oil scavenging.... thus no gravity drain issues. I am up in the air as to whether or not to continue with the project because we track our car more than anything else and I don't want to kill my motor with boost and heat....
I made my own brackets for both sides. I posted a thread on it some time back. Here's a photo. These bolt to the factory location, but I dropped the rear of the seat down to the floor to lower CG and offer more room for the helmet.
1971 RSR - interpretation |
I'm pretty sure these are 1 1/4" wide like you suggested by 1/8".
Driver's seat is actually a bit higher than the passenger and I rotated it a bit towards the pedals for optimal seating position. Use the old bracket as a template for the holes. Doug
I made my own out of aluminum and mounted them to the floor. I used large seat belt mounting washers underneath the car.
Shawn French Honorary SOCG Member and Keeper of the Titanium Monkey 1983 911SC Targa Kelly Green 1961 VW Ragtop 2001 Xterra 1997 Jeep Wrangler "The Tick" |
Friends of Warren
Doug
I think the problem here is that the seat already has mounting points on the bottom, as opposed to a racing shell that needs side brakets. |
If you are careful you won't kill your motor, but it might take a year to get it running just right, not sure if that is worth it to you. I'd love to help ![]()
Andy |
Got it! Maybe making adaptor plates from flat 1/8" stock is a good idea? I like the idea of using the stock mounting points. Why drill additional holes in your car if you don't need to? Doug
Limbo
It is a brand new pump that was designed and built by a friend of mine that is in the business of converting NA Porsche motors to Turbo.
I can get details of the pump and price points from him. I will of course ask Wayne before I post any info on where and for how much that these can be obtained for. They are very very nice and will fill a void for the guys that are upgrading turbos or converting their NA motors. Any help would be great because this is new territory for me..... ![]()
Limbo
Doug and Teo,
I would love to use the factory mounts in some way but after taking measurements of the seats, the base is too wide to fit in-between the factory rails. So I think my factory mounting rails will need to be removed and I will have to either fabricate new mounts or bolt them to the floor. I thought about bolting them in first to see how they worked and then if I liked it I could weld them in properly and undercoat it with some Wurth.
Big ol built Duramax Durango R/T 19’ Current Custom project V8 M3 08’ Built and spoiled Last edited by Slider79SC; 10-12-2005 at 02:20 PM.. |
Hey are those the " trendgear " seats from Ebay ?
Thanks, Todd ![]() |
Limbo
Todd,
These are made by Yonaka MotorSports, they are the Ronins in leather. Pretty decent for $600 a pair.
Maybe you could take a photo of the underside of the seat? Doug
Thread Tools | |
Rate This Thread | |
