Nitrometano's Avatar
Nuts & Bolts thread
Hi guys, I need the following info for a 1979 911 SC
What are the pitch of the threads of the nylock nuts used on the valve covers?
What are the long, width and thread pitch of the pressure plate cover allen bolts.
What are the long, width and thread pitch of the c.v. joint bolts?
Thanks.
Nitro
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 10-12-2005, 05:34 PM
syncroid's Avatar
The thread pitch for the valve cover studs is 8 x 1.25mm.
The pressure plate mounting bolts (allens) are also 8 x 1.25mm and their length is 42mm.
The CV bolts are also 8 x 1.25mm thread pitch and their length is 8 x 50mm. They are a 12.9 grade hardness.
Dan
2018 Jeep Compass
2002 996 C4 Cabriolet w/ Jake Raby 4.0
2001 Toyota Tacoma 4dr. 4x4
1997 Boxster
Old 10-12-2005, 05:58 PM
Thanks a lot buddy!!!
1972 911T
Old 10-13-2005, 08:26 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
