How to start an engine out of car?
I need to know how to start an engine on a test bench. Trans is hooked up including starter, fuel etc. I can work out the starter motor side of things, getting the engine to turn over, but how does one induce a spark. I assume getting power to the coil????
not sure I understand this... you just do what you'd do in the car - run 12 VDC to the ignition system
It's just like an engine dyno setup w/no dyno.... Do you not have the ignition system?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Make sure it is secure - clamped down somehow-, use a well charged battery and it will run (have enough electrical power)for a lengthy time
I watched someone do this long ago.
He had the engine (V8) on an ordinary engine stand. When the engine started, it flipped over and almost killed 3 people that were standing too close. The monster would not stop, was upside down for a long time still running (fuel injection) and if not for the serious part, would have been funny. I cannot stress the importance of bolting it down FIRMLY enough!!! Think about it...the torque...perhaps 150 - 200 lbs, is going to twist that engine. Whatever the engine is bolted to must be bolted to the floor able to withstand at least 500 lbs of torque to be safe. Havs a fun time... Bob
Bob Hutson |
For every action there's an opposite but equal reaction.
2014 Cayman S 2011 Cayenne Turbo 1979 930 (475 rwhp at 0.95 bar) |
Used User
I would think getting fuel to the motor would be the toughest problem. You need the fuel pump from the car, i.e., FI or carbs.
Porsche engines sitting on HEs should be OK to run briefly. Strapped to a large, sturdy pallet would be helpful. A V8 is top heavy to begin with, so I'm not a bit surprised that turned into a goat rope. ![]() As always, keep a fire extinguisher on hand.
My FB page: www.facebook.com/oddjobfix Antique and Collectibles Repair and Restoration On YouTube at "oddjobfix" |
Senior Member
That's what I was going to say. When you bench test a starter (which is a 1-2 hp motor), you do it on the FLOOR with your foot holding the motor down. With an engine, the torque is going to be violent to say the least.
Man of Carbon Fiber (stronger than steel) |
What?!?!
Uh, what about the oil tank and getting oil to the engine? I would think that part is every bit as important to the task as fuel/spark or securing down the engine.
Isn't it bad to attempt a cranking compression test without an oil supply?
running shoes, couple tools, fishing pole 1996 Subaru Legacy Outback AWD, 5speed 1964 Land Rover SII A 109 |
how about NO
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted. |
Platinum Member
I think the answer depends on the particular engine, and why?
I once ran a carburated v8 by just supplying gas (gravity feed) and 12 volts to the starter and ignition. A Dry-sump engine such as an early 911 would need an oiling system in place also. A later 3.2 or 3.6 would need computer, wiring harness, etc. and would probably not be worth the trouble. It may be easier to just spend the few hours necessary to bolt it into a car. Why would you want to do this? If you are purchasing an engine out of the car, more information about its condition could be had by testing. I would do a compression & leakdown test, pull the valve covers, and look at the drainplug etc.
This space for rent. ![]() |
You should also be a little concerned about venting exhaust gas. Just like a car, don't run it in an enclosed space.
As an aside, I saw the impressive engine dyno room at S-Car-go Racing. In the middle of the control panel is a huge red kill button. The label under the huge red kill button says, "Oh Sh*it!"
Don Plumley M235i memories: 87 911, 96 993, 13 Cayenne |
engine
Hello
we do it with a 912 engine ! this is the set up of Starting . Ray ![]()
1960 356 BT-5 Aetna blue 1973 911 RS récréation 1960 VW panel Dove blue 1971 914 barn find ! |
Cool looking instrument panel you got there.
Crusty Conservative
I think this is from Wayne's files...
Bill 69 911 T Targa, 2.4E w/carbs (1985-2001) 70 911 S Coupe, 2nd owner (1989- 2015) 73 911 T Targa, 3.2 Motronic (2001- ) |
Thread Tools | |
Rate This Thread | |
