Im so confused on this H4 Euro upgrade thing
I've been reading all the posts, but I still cant figure out what I need to actually do for my car.
I have an '86. Im pretty sure its and H4 bulb, b/c right on the lens it says H4.
I bought the Euro combo kit with trim ring. Im I right in thinking the this is a plug and play thing?
This is the part:
1986 944 Turbo - Guards Red
Old 10-13-2005, 06:20 AM
Friend of Warren
You are correct. However, I would recommend you use relays when you install the lights. Takes the load off the headlight switch and wires. Many of us use the Sucro relay kit which is inexpensive and can be found here: Sucro Relay Kit
And looks like this:
And here are the H4's on my car:
Kurt V
Old 10-13-2005, 06:32 AM
DeutschMark's Avatar
You should have everything you need with the kit. There is one screw at the bottom of the assembly for mounting, and the rest are for adjustment.
95 540i/6
89 R100RS
Old 10-13-2005, 06:33 AM
I was just reading the information above the part where you order it and it says you need another cover to cover up the black trim you see in the pic above. I didn't realize that - is this true. I thought the black trim in the pic was the cover trim?
Old 10-13-2005, 06:37 AM
Friend of Warren
That would be the "paintable" trim ring. On the other hand, I just ttaped off, scuffed up and painted the ring that came with the lights
Kurt V
Old 10-13-2005, 06:41 AM
K9Torro's Avatar
Yeah everything Kurt said -
Todd
Old 10-13-2005, 07:24 AM
450knotOffice's Avatar
I would HIGHLY recommend that Sucro relay kit. It's cheap, easy to install, and allows for much brighter headlights than otherwise.
Do a search and you'll find out all the details you need to know about it.
Old 10-13-2005, 08:27 AM
mschuep's Avatar
Just so I know, is it impossibe to repalce stock headlights with H4's and use original headlight trim?
---Nevermind, I found another thread that answers this and other questions thoroughly. here is link if interested.
H-1 H-2 H-4 H-5 ???????
-Matt
-Matt
1985 Targa
Old 10-13-2005, 10:32 AM
Porsche Less Member
k9handler's Avatar
Send a message via Yahoo to k9handler
I have mine back on after paint...but I am having trouble getting them adjusted properly.
H.D. Smith
2018 Ram Power Wagon "Crystal Black"
2016 Dodge Charger SRT "Go Mango"
2019 Can Am Renegade 1000R XC
Old 10-13-2005, 11:43 AM
the painted trim rings have a way of not wanting to fit real well, so some extra effort may be necessary. if you use the standard 55/60 watt bulbs, you can skip the relay. it's for the 100 watt high beams that can melt the dimmer switch. depending on the condition of the car's wiring, you may get a tad more voltage to the lights with the relay, because it's a direct 12V source that doesn't go through various switches and connections before delivering the voltage to the lights.
206 637 4071
Old 10-13-2005, 12:52 PM
I certainly noticed a difference.
Old 10-13-2005, 07:10 PM
78-911SC's Avatar
Are the Bosch H4's a direct plug in for the early 911's(70T)? Or do you need to buy adaptors?
PJ
78 911sc Targa
70 911T
Old 10-13-2005, 08:31 PM
KobaltBlau's Avatar
Nice post, Kurt. what about H1s in a 78-89 car? go, or no go?
Andy
Old 10-13-2005, 08:46 PM
Andy;
H4 and H1 lights mount the same. They'll both fit your car.
JR
Old 10-14-2005, 04:43 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
