930 backfire
On my 78 930. Pulled the fuel relays before a trip out of town. Replaced them a week later upon return. Car warms up and idles for a minute or so before it starts to backfire at the exhaust. Starts with a popping, and then gets louder, very loud. Drove the car a bit and it ran like the timing was out. Filled the tank with good gas and Chevron. Pulled the plugs, not bad, just a bit blackish. Ran just a bit better. car will drive but runs like it's out of time, and wont get full boost. Upon acceleration, car will backfire. Put my had to the exhaust (Borla Qaud outlet) It is a mini explosion out the tail pipe. Pulled the distrib cap, all looks ok inside, checked the vac advance, it moves some. Not sure how far it's gonna move. Sitting in the garage yesterday car reved up fine in neutral.
Help. Send experts. Where do I start looking? |
Checked for vacuum leaks?
Merv '89 911 Turbo Cab Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition ![]() |
I'm with Bill
That'll teach you to take a trip and leave the car at home. It seams odd that the car would perform like this just by sitting.
I recomend appoligizing to the car for leaving it alone and see if you are forgiven. Sorry I just couldn't pass it up
Electrical problems on a pick-up will do that to a guy- 1990C4S |
I can't see how pulling the relays would affect anything. Do you hear any new exhaust leaks? I take it this is much more popping than the usual decel popping.
2014 Cayman S 2011 Cayenne Turbo 1979 930 (475 rwhp at 0.95 bar) |
Try not, Do or Do not
It sounds like you are not getting power to the warm-up regulator.
The warm-up reg is a fuel pressure regulator that when warm raises the control pressure causing the engine to run leaner when warm. If it is not working the car starts well but then gets very rich causing back fires and dying at idle. If a fuse or wire to this regulator comes lose it will act just like you describe. The same circuit operates the auxiliary air reg. This add to idle speed when cold. I would look to that circuit. Good luck.
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Now the Henry mentions it, it does sound like a CIS pressure problem. Is there any popping from the intake?
Rick V. I tried to find someone to drive it for me while I was at Road Atlanta, no takers! 125 Shifter, More popping then the dec sounds. I haven't found any exhaust or any vac leaks. No popping on the intake side of things. Thanks Henry, I'll check your tips.
Designer King
Popping from the exhaust usually indicates a too rich mixture, as others have said. Maybe your setting is off. What happens if you lean it slightly (say in 1/16 turn increments)? If you do not feel comfortable doing this, have someone w/ an analyzer check it.
Just another thought: I know the SCs didn't get one til 80, but maybe the turbos were ahead of them. Do you have an O2 sensor?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L '80 SC engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Goodrich G Force Sport Comp 2; PCA/UCR, MID9 Never leave well enough alone |
If it is running too rich, we want to know why and only then do you want to change something. It is very common and tempting to try and repair a problem by simply adjusting a screw. Sometimes an adjustment is all you need but most often something has changed (failed) and by changing the adjustment the symptom may become nullified but the problem still exists. Find out what is missing and you'll know what to fix.
Designer King
Henry,
I don't disagree in principle, which is why I suggested bringing an analyzer to the party as an alternative, especially if someone is uncomfortable w/ doing their own adjustments. However, you know that sometimes these things need to be adjusted because of changes in ambient temp. This is very common here in this part of the world, although I admit our temp extremes are probably more varied than the poster's. 930 guy, Do you have a fuel pressure gauge so you can check your control pressures? BTW, does anybody know if these cars had O2 sensors or did they come in '80 as w/ the SCs?
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L '80 SC engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Goodrich G Force Sport Comp 2; PCA/UCR, MID9 Never leave well enough alone Last edited by Paulporsche; 10-14-2005 at 01:57 PM.. |
I've ordered a new large vac line to the aux air valve to be certain it doesn't leak. I'll follow up on Henrys advise and check for power at those circuits. I have been blowing a fuse to the blinkers on a reg basis. Does anyone know if this is on the same circuit?
Update, this am I put on the to-short vac line to aux valve. Car acted the same (still popping) with the addition of uneven idle up and down. Pulled the plug to Aux valve, I have power to it. Pulled plug to WUR, power as well. Replaced power plugs and started. Ran fine , nearly 95 % of the power it always had. Seems to be ok. I have less popping of decel. I don't yet have gauges to do CIS tests. Does this mean my WUR is bad?
Designer King
Most likely culprit is an out of spec or bad WUR. If you search WUR you will see they usually go out of spec but can be reset. By checking your control pressures you will be able to tell.
Thanks everyone. Running much better. I advanced the timing a couple degrees. (the cams were clocked wrong when rebuilt so I can't use the timing marks) Once I purchase CIS gauges, I will test all the pressures and adjust accordingly. b
Thread Tools | |
Rate This Thread | |
