KobaltBlau's Avatar
Details on Scruffy's chassis reinforcements (Please, Tyson?)
With all this talk about one of this board's favorite 911s, Scruffy, I wanted to see if I could get Tyson to put down some information in one place on the chassis reinforcements he has tried on that car, and what worked and didn't. Maybe James could even take a few pictures once he knows what to look for.
I remember something about a tube going down through the smuggler's box area... some creative stuff as I recall.
Thanks in advance!
Andy
Old 10-13-2005, 05:05 PM
aftermath's Avatar
bump, Ive asked and wondered about this without any info I can use. I know that TRE would do the work but I live far far away.
theamsoilguy@hotmail.com
Old 10-13-2005, 07:59 PM
Ove Ove is offline
911 driver
Ove's Avatar
I second the request for more info on the reinforcements.
I remember there was a description in an old thread here at the BBS, but no pictures. Tubes going from the front struts to the center tunnel in front of the shifter(?)
Come on Tyson, tell us more about it
EDIT: Here's the old thread: Targa to Cab conversion people
Ove
'77 911S targa
Old 10-14-2005, 09:27 AM
KobaltBlau's Avatar
That's the one I was thinking of, Ove.
Originally posted by Tyson Schmidt
The next move was a drastic one. I wanted to eliminate as much twist as possible. This has the most benefit to handling for the reasons you stated above. My solution was to tie the upper strut mounts to the center tunnel (Right next to the drivers feet.) with 1" tubing. I cut holes in the trunk floor, reinforced the center tunnel, and welded in the tubing. (There were many many obstacles to overcome, including some serious throttle pedal rearranging.)
James, is there any chance you could get some pictures of this?
But, I still had that annoying cowl shake, .... After the diagonal bracing was installed, it was GONE!!!!
Tyson, what suspension were you running on the car at the time?
Andy
Old 10-14-2005, 09:43 AM
PRO Motorsports
Tyson Schmidt's Avatar
I've got to get to work, so I'll have to go into more detail later. The diagonals that I put in the front had to be removed for rules reasons, so they aren't there anymore. It's not possible to do them on a power brake booster car either.
If I were to do it again, I'd make a structural sheet metal box where the ceneter console would be, then diagonally tie the upper strut mounts to meet the upper attachment point of the console at the trunk floor.
'69 911E coupe' 2.7E MFI (retired 911-Spec racer)
'72 911T Targa (Formerly "Scruffy")
2004 GT3
Old 10-14-2005, 10:25 AM
randywebb's Avatar
Thanks - if you can show any diagrams of what you did AND what you'd do next time, etc. I think many people would like to see it -- there are 341 vies already!
Also, did you put new spot welds into the unit body in between the ones that are already there?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 10-14-2005, 12:57 PM
PRO Motorsports
I'll have to get back to this later, since I can't post pics from this computer. Long story, but I've got to get my camera software on this computer before I can really post anything meaningful. (computer fried, and lost all my saved pictures too.)
I also don't have the photoshop or cad-cam skills, so I'll need help with that.
2004 GT3
Old 10-14-2005, 04:15 PM
KobaltBlau's Avatar
Thank you for being willing to do this, especially considering your last 24 hours or so. Maybe you could just make sketches and someone could scan them for you if you don't have the scanner. If you have any photos still of course that would be great too. CAD etc probably isn't necessary on this one, I'm curious about the general ideas
Cheers,
Andy
Old 10-14-2005, 04:22 PM
aftermath's Avatar
Tyson thanks in advance. Im still looking for where you might strengthen a tub. I plan a cage that extends to engine area ( actually talked to someone at TRE about you guys making a cage to ship to me ) but that wouldnt cover the 'extra' welding areas.
Old 10-14-2005, 05:19 PM
Sports Purpose 911 Driver
mjshira's Avatar
hey, what do you "once I know what to look for"...? ;-) maybe I do and just dont want to share?
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 10-14-2005, 07:29 PM
KobaltBlau's Avatar
Hey, I was sure you would want to share with your pelican bros!
Andy
Old 10-15-2005, 12:06 AM
mjshira's Avatar
I will let Tyson explain them all. We took out one bit of em because it made the car too tight. I will be able to see what our latest efforts produced when I put the roll bar back in.
Old 10-15-2005, 05:06 AM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
