Dumbest Question of the Year?
Ok guys,
Doing my first oil change on the car (ashamed to say that it has been a year and I havent put on 3000 miles). Warmed the engine up. Went to the dry sump bolt with a 19mm socket. Turned it counter clockwise to loosen. That thing would not budge. Put some oil on the bolt. Wacked it with a hammer. Eventually put an extension on my socket ratchet to make it into a breaker bar and the ratchet cracked in half. What the heck am I doing wrong? ![]()
Alexander '75 911S Targa '86 951 SOLD |
durn for'ner
Believe me Alexander, I can feel your pain ! For reference - read my thread on gear lube change.
I went at that plug for three days strait before it gave in. And the gear box filler plug its much worse located than the engine oil plug. Took heating, oiling, knocking, several attempts with different homemade extensions. Three f#Ī%&% days !! I canīt figure out any advice I did not try - so I have none to offer besides that of not giving up. Eventually one have to leave to the shop of course... but give it a bit more spanking and foul language before that. Good luck ! ![]()
Markus Resident Fluffer Carrera '85 |
You're not alone!
-my first Oil change went in similar fashon! the PO's mechanic must have used an air wrench or some idiot kid to tighten the bolt! -I ended up buying a big 2' extention, sprayed the tank and sump bolts with pentrating fluid, and then went to it. Constant Pressure seemed to work-as apposed to pulling as hard as I could!-plus you don't want to strip the bolt. -FYI-make sure you have a big bucket ready -that oil comes out FAST!!-If you are a newbie mechanic-and probably good advice for all of us, put on safety glasses! you dont want hot oil splattering in your eye! |
Cigars and 911's -- Smile
You've probably already - but try PB Blaster?? And let sit, and reapply and let sit, and reapply....
[GruppeB # 978] 1978 911 SC ROW (Pure Euro, no DOT or EPA work done..) 1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket) 2001 Audi - A6 Quattro 4.2L-V8 (love the growl) 2014 Honda Odyssey for the soccer-team/accessories |
Bill is Dead.
A related comment: Use a good quality tool. Cheap sockets (china, taiwan, etc) can expand under high loading - allowing the socket to jump the points of the bolt and round the corners.
Once the bolt is damaged, the level of difficulty removing it increases. Snap-On has a remedy called a "salvage socket", which has internal teeth that bite into the metal when turning. And although steady pressure is a good rule, sometimes a good impact will do the trick a lot faster. Just only use the impact for removal - never for installation. Again, make sure it is a good socket. And never use an open end wrench or adjustable wrench on highly torqued bolts. (comments based on my experience - others may feel differently)
-.-. .- ... .... ..-. .-.. -.-- . .-. The souls of the righteous are in the hand of God, and no torment will ever touch them. |
careful with pb blaster... flammable if torch applied.
Looking for 87-89 Silver Cab 911, black interior, must be low miles, near pristine, no accidents, well sorted. |
Ok guys, Its off.
I sure am relieved. Used a 2' pipe with letting it soak with PB blaster for an hour. Just needed a punch in the arm from you guys. ![]()
Vinyl guru ask 4 a quote
Make sure you use 10000 foot pounds of torque when ya put it back in....%^B
1983 cab. 3,6 lots of other stuff. Now the daily driver. 2012 ML 350 Parked. Check engine light on again. Fuch it. |
Thread Tools | |
Rate This Thread | |
