Fresh Air Intake
I just installed a fresh air intake in my '85 911. Well after I was done I noticed a hose not hooked to anything hanging there. It turns out that it hooks up to the factory air box. There isn't a place to hook up this hose to my new intake. Does anyone know what this is for? What should I do with it now? Plug it? Leave it hanging there? Tie it up out of the way? Any help on this would be great.
Thanks, Bill ![]() ![]() |
I may be wrong but I had the same issue where it came loose from my box. I think someone mentioned that it goes to the charcoal canister. (I'm not sure where it's located or what it does but I think it's for emisions.)
I would think you could just leave it. Hope some one else can shed some light on it. by the way did the intake help in any way? |
Friend of Warren
Correct it goes to the charcoal cannister located in the right rear fenderwell. A number of aftermarket mounting plates with a vacuum hose connection. Won't hurt to leave it disconnected.
Kurt V No more Porsches, but a revolving number of motorcycles. |
Thanks a lot you guys. I won't worry about it then. I'm just going to tie it up out of the way. That's why I love this web site for stuff like this!!!!
Thanks, Bill |
Cigars and 911's -- Smile
I had to comment quickly, I love it when MY garage ends up looking just like another Pelican's -- can of PBlaster, Stabil, and Oil. I have the same order even on my shelf.... TOO FUNNY.
[GruppeB # 978] 1978 911 SC ROW (Pure Euro, no DOT or EPA work done..) 1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket) 2001 Audi - A6 Quattro 4.2L-V8 (love the growl) 2014 Honda Odyssey for the soccer-team/accessories |
Be careful and check if it isn't the breather that (stock) goes into the air intake. If that's the one...it'll "vapor" the engine compartment and make a mess.
Either find a way to hook up to similar nipple..or have it dump into a washer bottle-type device....but arrange it so it has a liquid drain valve on the bottom and a vent on top.....the little vent on top should then have a mini version of the cone filter shown as for the normal, aftermarket-style air intake. Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
It is definitely the hose that hooks up to the factory air box. The aftermarket intake doesn't have a place to hook this hose up. I've driven the car a couple of times and it doesn't act like it needs to be hooked up. How does it make a mess? Does the canister purge out this hose and into the air intake? That's scary..
And to answer Steviee 7's question: After driving it a couple of times I can't tell the difference. Not even in the sound department. This was just the first part of a bigger plan. Next I'm putting on a performance exhaust and performance chip. I'm also starting to backdate my engine compartment. Thanks, Bill |
Thread Tools | |
Rate This Thread | |
