Crank Pulley Torque??
This'll probly make me sound like a complete idiot, but I'm used to that...
My crank pulley keeps coming loose, and I can't figure out why. After getting my engine from the PO, I discovered that the pulley was loose and VERY worn with about a 3/8" groove worn by the retaining pin from tha back and forth slap. I got a new pulley and installed it. Because access was so difficult, I just tightened the thing as hard as I could. Within about 10 miles, I could hear it rattling again, and sure enough, it was loose. Two questions: What is the torque for this bolt? Am I missing something, here? Is there some problem that would cause the pully to loosen so quickly? It was obviously a problem for the PO (who managed not to mention anything about it to me ![]() Any suggestions on what I need to do here would be appreciated greatly. Thanks!
'73 914-6 3.0SC '69 Jaguar XKE '05 Colorado Crew Cab |
To properly tighten the pulley, one likely has to remove the muffler, support the rear of the engine and remove the back engine tin, rear engine mounts and console (bracket around pulley).
The torque is likely 125 ft-lbs; see the below link and make sure you're using the correct screw: PN 999.093.005.02, a M12 x 1.5 x 22 with Durlok head. crank pulley bolt - washer or no washer Last edited by Jim Sims; 10-14-2005 at 09:06 PM.. |
![]() Man, I thought I was going crazy ![]()
Thread Tools | |
Rate This Thread | |
