Steering help
I have a pinch, or a spot the the steering seem to get caught once on every full turn.
It is in the same spot as you turn the wheel. It is like it's hitting something. I have looked over everything with no luck. I was thinking of changing out the bushing , that is in the trunk. Has anyone ever had the problem?
Derek Oxford PCA - Nationally Certified Instructor 2002 Boxster S ( race car) 2010 LR4 2009 GMC Sierra (Porsche Support 2011 M3 4Door |
Will program for food
Nope. But I would check the steering rack - maybe the problem is there. Also check the tierods and make sure each wheel turns without binding. Any other suggestions?
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
durn for'ner
I would also take a look at the tie rods. If they have been adjusted previously in a manner make one rod "longer" in reference to the steering rack - that could create a binding feeling.
Hope you can understand what I mean, wish my English language had more useful tech words in it - but alas.. ![]()
Markus Resident Fluffer Carrera '85 |
Try loosening up the clamps on the steering column u-joints and then turning the steering wheel. This may eliminate the problem and then you can re-tighten the clamps. I recall that there are several posts about this same problem after installation of the bump steer spacers. You might want to try a search on that topic.
Thread Tools | |
Rate This Thread | |
