3.4 Bigger is better
88-diamondblue's Avatar
Engine drop (so far)
Got the drop done today, no problems just a few connections that I found after I the engine was down about 6". I will document later some of the things that are different with G50 Carrera's if anyone is interested. All the tips from everyone helped a lot. Here are some pictures and the results of seperating the trans. The forklift worked great. Did the drop solo. Everybody else just watched. Was able to tilt forward and back to get the shift linkage out. The engine mount got tweeked on the left side due to being too tight.
The clutch fork needs the G50 upgrade
The clutch.. Ouch! Figured this was the problem.
More to come...
Michael
88 911 Diamond Blue CE Carrera 3.4 HC3.4 member
2020 Honda Passport
Old 10-14-2005, 10:17 PM
Will program for food
ghnat's Avatar
Nice job - and solo to boot. Sorry bout the clutch problems. Can you machine the flywheel or is it toast?
Greg Hnat
87 Targa Disassembled
90 944 S2 Auto-x, DE and semi-daily driver
98 Jeep Cherokee
Old 10-14-2005, 10:21 PM
Not sure on the flywheel. We have a place in town that I will have look at it to see if it is ok. All they do is sell clutch and driveline parts plus the best machine shop in town IMHO. I have read not to surface a G50 fly wheel just not sure why. The fly wheel looks worse in the pictures than it is.
Michael
2020 Honda Passport
Old 10-14-2005, 10:31 PM
sushinav's Avatar
Any idea what failed first? I've read that the later G50 rubber center clutches are NOT prone to failure like the earlier ones, but looks like this is what may have happened. Great pics, keep them coming, this is superb material for this tech forum.
...sick with gearheadia
Old 10-14-2005, 11:25 PM
Jason,
The day that it happened I had run the car to about 143mph. About an hour later I was passing a truck and I thought that I pushed it out of gear early, 2nd to 3rd not so sure anymore, it may have just failed. I do believe the age and the high speed run may have caused it to start to let go. How's your car doing since all the updates? Didn't have my camera better pics tomorrow.
Michael
2020 Honda Passport
Old 10-14-2005, 11:35 PM
87coupe's Avatar
Nice The more info the better, I'm needing to do the cross shaft update as well and am feeling a little intimidated by the solo first timer engine drop. Most of the info I've been able to track down is for 915 cars. Thanks in advance.
ßrandon
Old 10-15-2005, 01:46 AM
Michael,
The Porsche spec book says the flywheel should not be machined .
Do the cross shaft update that does not reqire machining. I inspected my update after a couple of years and it is fine.
Job is looking good!
Ned NYNA 11
87 Carrera targa
98 BMW 528i
98 Volvo V70
Old 10-15-2005, 03:48 AM
sushinav's Avatar
Mine runs great and turned out just as I had imagined. Best of both worlds: 3.2 and G50, but early 70s RS style and weight. I have put it up for sale as I'm now craving a Boxster after having 2 911s and a 951. Time to try another flavor.
87 Coupe, don't be intimidated, just read the Pelican instructions and do it in sections. Top right of engine first night, top left of engine 2nd night, underneath and drop the 3rd. Use a rolled newspaper on your jack and get the balance point right where the engine and tranny meet, and you can do it with a friend quite easily.
Old 10-15-2005, 08:49 PM
VMAX1's Avatar
My clutch went out with a bank!! Had to have the tranny updated. Don't have the flywheel resurfaced, get a new one-DO NOT forget to get the ring gear off of the pressure plate, like I did....more money!! Gooo Luck
Old 10-15-2005, 10:21 PM
87coupe's Avatar
All my freinds are dipsticks when it comes to mechanical things so I think I'm flying solo on this one ... thanks for the advice and encouragement.
ßrandon
Old 10-15-2005, 10:42 PM
Czar of C.R.A.P.
dfink's Avatar
Mike looks like you got it out OK. Glad to hear everything went well and no major snags. Do you get to drive the GT while the 911 is out of commission. Was looking for a Bently repair manual today and ran across a book on the Ford GT. Brought back a grin. Have fun and post lots of pictures. Wish I had that huge shop and a fork lift.
66 912 Coupe
84 Carrera Cab Hardtop HC3.4 Hyper Carrera
2005 Dodge Magnum 5.7 HEMI
Cabriolet Racing And Performance C.R.A.P. Gruppe #1
Put on some C.R.A.P. and drive....
Old 10-16-2005, 06:24 PM
Here are a few pictures from yesterday and today. Need to get the cam bar tool before I can do much more and I now understand the right tools are your best friend, heat helps a lot too. I've tried to get the GT but no luck with that, yet
With the intake gone
Chains exposed
My engine stand till this afternoon
Taking the car home
Mounted on the stand and used lots of heat the nuts came right off
Michael
2020 Honda Passport
Old 10-16-2005, 08:14 PM
Cigars and 911's -- Smile
acapella8's Avatar
Send a message via AIM to acapella8
Great Pictures, I've learned by looking at some of these. Thanks.
[GruppeB # 978]
1978 911 SC ROW (Pure Euro, no DOT or EPA work done..)
1991 Toyota MR2 Turbo (3S-GTE 4Banger Rocket)
2001 Audi - A6 Quattro 4.2L-V8 (love the growl)
2014 Honda Odyssey for the soccer-team/accessories
Old 10-16-2005, 08:21 PM
The engine drop and tear down has not been hard. Read all you can leading up to the drop date. There are a few must have tools that it can't be done without. It took longer that I planned but I haven't hurried the process. You would need another person to do the drop with a jack. It has been enjoyable to do and am looking forward to getting back to it in a couple of days. Just a few more pics.
The intake valves
The exhaust valves, Does this look normal?
And oh yes the obligatory engine compartment shot.
Michael
2020 Honda Passport
Old 10-16-2005, 09:17 PM
ghnat's Avatar
Congrats! Now wipe that smile off your face I bet it takes a day or 2 before that happens. I know I had a ***** eatting grin for a few days!
Greg Hnat
98 Jeep Cherokee
Old 10-16-2005, 09:22 PM
GOT TURBO..
MobileWrks's Avatar
Pop- goes the weasle
Old 10-17-2005, 11:25 AM
GOT TURBO..
MobileWrks's Avatar
ohh yah... good job on the drop... and with a forklift... NICE!!!
Old 10-17-2005, 11:26 AM
MobileWrks
Thanks, it was a lot of fun and the forklift made it easy. The forward/backward tilt made getting the shift linkage out easy. Have the engine torn down to the point that I need the cam bar to finish. Great picture, its a good feeling when its done.
Michael
2020 Honda Passport
Old 10-17-2005, 07:54 PM
GOT TURBO..
MobileWrks's Avatar
Oh yah, the tilt on the fork lift.. Forgot about that... Thats really cool.. take pix as you go, and share.. Good luck and have fun....
Old 10-18-2005, 08:19 AM
