Targa stiffness
Hi,
What to install first? Targa body brace or front strut tie bar? Can't do both at once at the moment. Thanks! Dave
Make sure to check out my balls in the Pelican Parts Catalog! 917 inspired shift knobs. '84 Targa - Arena Red - AX #104 '07 Toyota Camry Hybrid - Yes, I'm that guy... '01 Toyota Corolla - Urban Camouflage - SOLD |
Darn, posted to wrong forum! how to move??
Dave
entertaining the idea
buy a 944..problem solved
There are some who call me... 'Tim'. a well set-up 1983 Guards Red 944 |
Um, yeah, but no, car has special meaning to me...
Slackerous Maximus
Explain what you mean by "body brace".
1992 Ducati Supersport. White frame, Ferracci pipes, open airbox. Mercedes E350 family truckster. 2003 Mustang Mach 1....SOLD....now what? |
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_SUSshk_pg7.htm#item31 Dave
fancytown
The word "on the street" is that doesn't do anything. I have a bolt-in autopower roll bar in my '78. I find the car to be very stiff, even with the top off.
all cars sold. |
Triangulated strut brace. Serious, immediate changes. You won't need anything else.
Slackerous Maximus
I have also heard that the braces do nothing.
Registered Loser
I own a Targa and have no problem with stiffness.
![]() Question: has anyone tried to intergrate a better roll bar into/under the stock roll bar for added body stiffness? ![]() Was the Shelby roll-bar a functional one? ![]() ![]()
1977 911S Targa 2.7L (CIS) Silver/Black 1998 Chevy S-10 4x4 Pick-Up Truck, Razzle Dazzle Camo 1989 modified Scat II HP Hovercraft George, Architect |
Registered Loser
kach,
I don't have a girl. My dad and I share yours. ![]() |
Hi,
My '88 Scirocco had bigger f/r sway bars and the front strut tie bar. I noticed a big difference in stiffness over stock. I never did install the rear triangulated strut bar as I was in college and needed to be able to haul my stuff around. It just seems to me that when I have the top off and the windows down, the car twists a bit more. I also had thought that by adding the front strut bar that it would magnify the twisting with top off.... Dave
Tell us if it is steet, DE, race, AutoX or what...
There are a number of things that are supposed to stiffen up the Targas. You might want to spend (a lot of) time searching and filtering out inappropriate threads. Also, I'm sure Thom has done some stuff on his - ah - modified vehicle.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I have a small company and unjustified rumors can affect my business. So unless you personally have knowledge of any product not doing its job please don't spread rumors. I have said it before and will say again that if the Targa bars do not perform as advertised then send them back . Jerry JM PRODUCT DESIGN |
Wider is Better
There is not doubt that a triangulated roll bar is probably superior, but I am a family man and need to put children in the back seat. I plan to put then in my car even though it feels pretty tight, because if it slows down the inevitable cracking of the body in front of the door pillars, it will have been worth the expense.
Wider is Better |
Senior Member
Strut bar helps. Also harness bar (just empirically knowledge) makes the roof "squeak & rattle" less.
Targa 88 www.pelicanparts.com/gallery/targa88 There is speed.... and then there is VELOCITY |
Well, I can't tell you what to do first. When I was looking at similar questions I found lots of opinions but nothing really definitive.
I can tell you that after a couple years of upgrades, my targa is very stiff (but still seems fine on the road to me). Here's what I've done: Koni sports all round Weltmeister strut bar Speedware harness bar with targa down tubes (mounts to seat belt mount-points) Beefier torsion bars TRG sways Elephant racing bushings Turbo tie rods New A-arms And of course, alignment and corner balance. The car really, really handles nicely.
1985 Carrera Targa |
Virginia Rocks!
When will you "non-owners" learn? If you don't try it, you won't know. ![]() I actually bought a set and while it still isn't (and never will be) as stiff as a coupe, it stiffened it up a little. FWIW, I am still in the market for a shock tower brace, because that works to solve a different issue.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
Thread Tools | |
Rate This Thread | |
