Seat installation gurus
Anyone have a tip or two on how the hell to tighten down the bolts that affix the rails to the seat mounts?
I've removed and installed various seats in Porsches, and other cars, over the years, but today it got maddening. I can't get an allen wrench in the small space between the socket head bolt and the damn seat. Is there some other way to do this?
Remember our friends: Warren, Ron, and Grady 76 912E RS (i.e. "Real Slow"); 63 Volvo P1800 "S"; 71 Jaguar XJ6 Series 1; 05 GT3 |
Somewhere in the Midwest
Dave, on some installs, I have found it easier to tighten the sliders to the rails, then the seat to the sliders. If you are installing Carrera seats (sliders on) and your sliders came with the little tab washers for the front screws, take them out, and the seat will slide more forward. If you do the rear screws first, then the fronts it'll be eaiser(and you can us the stop tab washers). The seat slides more forward than they do rearward. so you start with the rears. The seat will just clear the fronts...enough to put a wrench on them.
Good luck. |
Driving member
You might try an allen socket wrench. That may not be the correct name but basically an allen wrench attached to a socket. I bought a whole set of metric ones and they come in handy on these cars. Also you can buy the allen wrenches that have the ball at the end so you can angle them a little.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
I am trying to install a pair of vintage Recaro Rallye seats. They just don't have the room to get in there with either a socket, a regular allen wrench or the round-ended allen wrenches. I was thinking of Souk's idea - installing the seat to the mounted sliders - but the metal frame of the seat bottom makes it impossible. This is a conundrum.
I wonder if someone makes allen wrenches with flat handles, so you can really get on top of a socket head bolt?
Slippery Slope Victim
Cut a regular long allen key and substitute it on the socket or buy a long allen socket. Works every time!
Good Luck
MikeČ 1985 M491 |
Mike,
Could you explain that a little differently? Sounds like an idea but I'm not sure exactly what you're saying. Dave
Souk's method works. That's what I did a few months ago.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
Pre Registered
Go to your local Radio Shack and look for this mini ratchet. I've used an older version (pictured below) to reach the allen bolts of my (Recaro made) factory Euro GT3 seats numerous times and it works well. Application specific tool in my case, but a great cheap tool nonetheless. ![]() Tim Last edited by tchanson; 10-15-2005 at 06:45 PM.. |
Thanks Tim, I will try that.
Dave,
Take a look here when I changed mine. But from my experience, remove the front allen screws first and then slide the chair forward to do the back. I was able to do this with a regular set of allen wrenches. Chris
Modes of Transportation: 1984 Porsche 911 Targa 2003 VW Jetta GLI |
Chris,
I used to have the exact same seats that you installed in that thread you linked. I've had those in/out several times. I agree, it's not too difficult. My problem, here, is these vintage Recaro seats. There just isn't the room above the socket head bolt to get any sort of a tool onto it. Dave
Cut an allen, then use an open or box end wrench. I have a generic tool kit from one of my venders that has allen inserts for a screw driver handle thing. The allen is about 1 inch long. I fit it into tight spaces, then put a wrench on it. Works good.
Great idea. I'll give it a whirl.
Thread Tools | |
Rate This Thread | |
