Licensed User
need the pinout for the '72 14 pin connector
Anybody have the pinout for the male connector that the '72 2.4 engine wiring harness plugs into?
Ive got the info for the 3.2 thats going in the car I just need to know which pins to leave out or swap on the 2.4 connector. TIA heres the 3.2 from Marqesqs site Quote:
Licensed User
Found this in an old post from Roland Kunz. Looks like a 2.7 MFI car. This should get me close. Can anyone confirm this is correct? Im looking for old posts from Warren or Grady. Im sure this has been covered before.
Licensed User
Sunday morning bump
Anybody have the pinout that can confirm my previous post? |
Shuie
I just went through this for my RSR Clone where I swapped a 3.0 SC into a 73.5 CIS Chassis. I used the alternator and engine wiring harness from the 2.4 CIS motor. I had to go through the wiring harness to remove all of the extra CIS stuff to clean it up. Here's a pic I used to help me through the rebuild of the harness. 14 Pin Male Connector from fuse panel to engine: ![]() Starting from top left and going clockwise, the connectors are: yellow-starter green/black-oil temp green/yellow-??? red/black-not used (blank on female connector) black/purple-dizzy blue-alternator black-alternator red-alternator brown-alternator red/white-WUR grey/red- not used (blank on female connector) grey-back-up light green/red-oil pressure green-not used (blank on female connector) I've also got some detail on the layout of the chassis to fuse panel 14 pin connector on the '73.5 if you need it. |
Thread Tools | |
Rate This Thread | |
