PAT4's Avatar
911 2.2 E pistons and cylinders
Hi all,
I am planning to rebuild my 2.2 T this winter and I am planning to replace my pistons and cylinders with a 2.2 E set to increase CR.
1 - is it a good idea
2 - do you think that I should get 2.2 E camshafts to run with (carbed 40 IDA)
3 - what is the right price for these parts, used in good condition
Old 10-16-2005, 02:51 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
I would even try to find 2.2S parts if possible.
1) It's a great idea.
2) Yes! You can reset your Zenith carbs and run them too...
3) Maybe me. Check the for-sale board, put up a wanted ad, etc., etc.
Scott Kinder
kindersport @ gmail.com
Old 10-16-2005, 03:31 AM
PAT4's Avatar
The fact that the 2.2 T crank is not counterweighted is not a problem to run 2.2 E pistons and camshafts ?
And may be my heads ports too small ...
Old 10-16-2005, 04:19 AM
YTNUKLR's Avatar
They are a little on the small side for an E grind now that I think about it...you could have them ported to maybe 31/31 or so and that would be ideal for a street engine on E cams. Not a problem to run the non-counterweighted crank (IMHO). It can take some rpm, especially if you balance it (even just matching rod and piston weights and such is very beneficial). Best, Scott
Scott Kinder
Old 10-16-2005, 04:28 AM
JCF JCF is offline
Use Solex (very early 911) cams - if you can find them, they are more streetable than the S cams but have more kick than the standard E's
John
Du must schwein haben
'67 901/05 rebuilt 2.2
Bultaco Metralla 62 "XDina"
'68 BMW R69S
Old 10-17-2005, 06:21 PM
Dan Morton's Avatar
I had my 2.2T rebuilt with new Mahle S pistons and cams reground to E specs. Didn't touch the carb settings. The heads were rebuilt by EBS to original specs if I remember correctly. Good power, a lot better than the T specs.
-Dan
--Dan
1968 911 Coupe
1970 911T Targa
1995 993 Coupe
1997 993 Targa (sold)
Old 10-17-2005, 07:03 PM
JCF JCF is offline
Dan;
What size venturis ?
John
'68 BMW R69S
Old 10-17-2005, 08:03 PM
PAT4's Avatar
On 2.2 T, standard venturi was 27, both on Weber or Zenith
Old 10-18-2005, 03:54 AM
Dan Morton's Avatar
stock sizes as far as I know. Probably could change them and get more performance at higher RPM's but am holding off for now. Runs great as is.
-Dan
--Dan
1968 911 Coupe
1970 911T Targa
1995 993 Coupe
Old 10-18-2005, 05:48 AM
The 2.2 have the same port and valve sizes for both the T and E. The S had larger valves and ports.
69 911 2.3Ez
85 928S
Old 10-18-2005, 07:58 PM
Try not, Do or Do not
Henry Schmidt's Avatar
In 1970-77 port size varied but all the valves in production 2.2 -2.7 were the same.
Intake= 46mm
Exhaust=40mm
E piston are cast not forged but I like the compression ratio of the E better than S considering fuel availability.
With carbs I like Solex cams. They were designed from a clean sheet of paper as the only cam available so it is a great all around cam for carbs. E cams were designed to run with MFI. $300 good used
I would run 32 mm venturis. Small enough for good low end and yet still flow enough air to run at top end.
Henry Schmidt
SUPERTEC PERFORMANCE
Ph: 760-728-3062
Email: supertec1@earthlink.net
Old 10-18-2005, 08:04 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
