87 911 Cab Sway bar mounts cracked
Need some input here. My friend has a 1987 911 Cab, garage queen, no hard driving. He has cracked the passenger side sway bar mount twice. The mount was welded back together after the first separation. I know the fix is not as strong as the original but I cant figure how he keeps doing this. I have seen this happen on race and DE cars but never on a street car especially the way he drives . Any specific model year problems? alignment? corner balance? anyone else experience this?. thanx in advance
Scott
1980 911SC #99 track car, 993 3.6, 50 PMO's 2001 BMW 330Ci Vert DD 2019 Tahoe 2015 SL400 wifey DD 2014 Unmarked Explorer "company car" |
I had the same thing happen on my 1987 Coupe. From what I have read, it appears to be a common problem with the original sway bar mounts. The fix is to have the old mounts removed (ground off) and new upgraded mounts welded back in place. The new mounts are reinforced on the back side and less prone to cracking. I had my local shop do the work for around $500 for both rear mounts.
George in Virginia Beach ![]() |
wevo sells better/stonger swaybar mounts
do a search here... there are detailed pics of them
WWW.9GEAR.NL |
Do you think years of stress just fatigue the mount? Even easy driving? The repair I am familiar with but I am wondering if it could be the result of something else causing excessive stress on the mount. Its definitely not his driving.
It's the original mounts - very weak design and they can break even with normal driving. I first did the factory replacement with the reinforcing panel, but tore that out too. Second round was the same mount with the Smart Racing reinforcement kit added (did that on both sides). So far so good. If I ever have to do it again I would definitely use the Wevo cast steel mount.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
MBruns for President
It's called better tire technology and wider wheels. I've torn mine out too - they should definitely be on the once every six months check for cracks list.
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Thread Tools | |
Rate This Thread | |
